boosted22 Posted January 22, 2006 Share Posted January 22, 2006 howdy, i recently installed a turbosmart eboost, but i cant seem to boost over 7psi, the guage runs three adjustable set points, which i have set at 1-7psi 2-10psi 3-13psi, i run the eboost soildnoid straight of the trubos wastegate, so there shouldnt been any factory boost cut out stoping it should there, any suggestions. Link to comment https://www.sau.com.au/forums/topic/102802-eboost/ Share on other sites More sharing options...
fEkuaR Posted January 22, 2006 Share Posted January 22, 2006 are you sure the standard boost solinoid isnt connected by another hose coming off a tpiece or something? Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1887888 Share on other sites More sharing options...
boosted22 Posted January 22, 2006 Author Share Posted January 22, 2006 theres only the one hose on there straight from the turbos wastegate to to eboost solinoid, is that what i ned to be looking at. Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888015 Share on other sites More sharing options...
Miller the hoon Posted January 22, 2006 Share Posted January 22, 2006 Wat setting (number) do you have it no i have eboost2 and run 10psi only all day james Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888144 Share on other sites More sharing options...
rob82 Posted January 22, 2006 Share Posted January 22, 2006 Make sure you have the solenoid hooked up correctly. Port 3 of the solenoid is manifold pressure, port 2 is actuator reference and port3 is vent. There are three setting boost setting - SP1, gate pressure and sensitivity. Set SP1 to you desired boost level then adjust the gate pressure until it just starts to overshoot your desired boost level and set the sensitivity so that boost dosn't drop off higer in the rev range. That said I have had alot of trouble setting these boost controllers and dont really have much respect for them. Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888152 Share on other sites More sharing options...
boosted22 Posted January 22, 2006 Author Share Posted January 22, 2006 Make sure you have the solenoid hooked up correctly. Port 3 of the solenoid is manifold pressure, port 2 is actuator reference and port3 is vent. There are three setting boost setting - SP1, gate pressure and sensitivity. Set SP1 to you desired boost level then adjust the gate pressure until it just starts to overshoot your desired boost level and set the sensitivity so that boost dosn't drop off higer in the rev range.That said I have had alot of trouble setting these boost controllers and dont really have much respect for them. <{POST_SNAPBACK}> cheers, il have another go at it, yer its a bit bloody tecnical for first timers like me self, gate pressure, sensitivity, heaps of stuff to mess with, but il keep at it, even when i reset it all and set sp1 at 10psi, still couldnt get over 7psi, checked the hook p three times now all looks right but will check once more just in case. Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888335 Share on other sites More sharing options...
rob82 Posted January 22, 2006 Share Posted January 22, 2006 cheers, il have another go at it, yer its a bit bloody tecnical for first timers like me self, gate pressure, sensitivity, heaps of stuff to mess with, but il keep at it, even when i reset it all and set sp1 at 10psi, still couldnt get over 7psi, checked the hook p three times now all looks right but will check once more just in case. <{POST_SNAPBACK}> The values you put in are a little miss leading as they are not in boost pressure. It may be Duty Cycle but I'm not really sure. So if you set SP1 to 10 it wont necessaryily give you 10psi. Try setting it 20 then 30 etc etc until you get the desired boost level and then you will proably find that you will have to increase the sensitivity to stop it bleeding off in the top end. Does anybody know if there is any kind of feedback control as in closed loop operation PI or PID loops, or is dumb as shit? Has anybody check the duty cycle on the solenoid to determine if it changes up and down or only up or does it change at all from the set DC. Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888352 Share on other sites More sharing options...
boosted22 Posted January 22, 2006 Author Share Posted January 22, 2006 ok just went for a spin out on the old knob high way messing around with set point one i tryed seting it at 20 with a gate pressure of 20, and then 30 with a gate pressure 30, done a few 1st and 2nd gear rolling take offs, evry time i booted it, it would still only get up to around 7.2 was the highest, but every time i changed gears, and flanted it again i would get a sudden boost spike to around 9 some times 10 but would drop straight away to 7 or lower. had the sensitvity high as well. dam thing would all ways crunch a little into 4th and 5th and back into 4th, at revs its ok around town driving or cruzzen. Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888502 Share on other sites More sharing options...
rob82 Posted January 22, 2006 Share Posted January 22, 2006 ok just went for a spin out on the old knob high way messing around with set point one i tryed seting it at 20 with a gate pressure of 20, and then 30 with a gate pressure 30, done a few 1st and 2nd gear rolling take offs, evry time i booted it, it would still only get up to around 7.2 was the highest, but every time i changed gears, and flanted it again i would get a sudden boost spike to around 9 some times 10 but would drop straight away to 7 or lower. had the sensitvity high as well.dam thing would all ways crunch a little into 4th and 5th and back into 4th, at revs its ok around town driving or cruzzen. <{POST_SNAPBACK}> Check the over boost isn't set at like 8psi. Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888507 Share on other sites More sharing options...
boosted22 Posted January 22, 2006 Author Share Posted January 22, 2006 ar crap yer forgot, to adjust the over boost still et preety low, that would of been stoping it any way, (idiot) oh well will give it another go tomorrow. Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1888542 Share on other sites More sharing options...
srbskyline Posted January 24, 2006 Share Posted January 24, 2006 get a blitz sbc Link to comment https://www.sau.com.au/forums/topic/102802-eboost/#findComment-1894399 Share on other sites More sharing options...
