Hey fellow wagoneers,
This thread is for all the DIY's anyone wishes to post (It may as well be called SK's thread). I'll stick a list of links from the Skyline DIY section that are applicable to stageas, so we don't double up. If you find something i havent yet, just PM me & I'll update it regularly.
Just remember, we take no responsibility to what you do you your car.
GENERAL
Australian Stagea Part Dealers
External Stagea Web Links
Stagea Parts List
Stagea Dyno Results
GLOSSARY OF TERMS
The C34 Buyers Guide
What do I need to do to my car before a track day?
Getting It Off The Line
FYI: Insurance for your stagea
SERVICING
DIY: Stagea 5000km Service
FYI: Air Regulator Maintenance
DIY: RB25DET: Changing the Spark Plugs
DIY: Changing the Oxygen Sensor, Lambda Sensor, O2 sensor, etc etc etc.
ECU
FYI: Series 2 (R34) ECU pinouts
FYI: copgy Backs
M35 ECU Fault Codes
ENGINE
RB26DET Conversion Tutaorial
DIY: RB25DET High Boost mode with standard solenoid
DIY: Adj Camshaft Pulley & New Cam Belt
DIY: Stagea Air Deflector
DIY: Oil Cooler Installation
FYI: Aftermarket Fuel Rails( thanks to SK)
Updates On The Jun 2.7l Staj Build
FYI: Max Hp Out Of Standard Rb25
FYI: Max Power Out Of Neo
How To: RB26 conversion
DIY: 5min $5 Intake Pipe Mod For Your Stagea/skyline.
TURBO
TUTORIAL - Guide To Selecting The Right Turbo
FAQ: Stagea Turbo Upgrading
DYI: Jaycar Boost and Fuel Control
FAQ: Turbo Timer Install.
FYI: SBC ID III vs AVC-R
EXHAUST
FAQ: Stagea Exhaust
FAQ: Split Dump Pipe
INTERCOOLER
FAQ: Stagea Intercooler
DIY: R34GTT Intercooler into Stagea
DIY: Water Spray For Aftermarket Intercooler
FYI: Check Your L/h Inner Guard Intercooler Exit
FYI: Intake Temp Cooling Options.
TRANSMISSION + DIFF
C34 Stagea CV Joint (and Boot) removal/replacement (and part numbers)
FYI: Stagea gear ratio's
DIY: Transmission Cooler
FAQ: Automatic Trans Thread
FYI: Stagea Diff - Is It Wearing Out - Replace With?
FYI: out goes the stagea diff in goes the GTR diff
DIY: Running your Stagea in RWD mode
FYI: Manual Conversion Checklist
DIY: Auto to Manual Conversion Guide - SAU
FYI: Why NOT to convert auto to manual + some manul conversion info
DIY: Stagea Auto Troubleshooting
DIY: How to SAFELY convert your AWD Stagea to RWD (for dyno days, etc.)...
BRAKES + WHEELS
Stagea Brake FAQ
DIY: Anodize your brake calipers
DIY: How To Paint Your Standard Brake Calipers
DIY: Stop your brakes squealing 101
FAQ: Stagea Wheel Dimensions
DIY: Stagea brake upgrade using R33 GTSt calipers and discs.
DIY: Painting your wheels tutorial
BODY
Car Care Prescription (detailing)
FAQ: Stagea Body Kits
DIY: Front Bar Removal
FYI Front Glass Tint
FAQ: Replacement windscreens
Tow Bars for Stageas
FAQ: Insuring your Stagea
FAQ: Alarm for your Stagea
DIY: Rear Taillights
DIY: Headlight Bulb Replacement
Stagea Bonnet Gas Struts
INTERIOR
DIY: Stagea Headunit/stereo Removal
FAQ: Stagea Floormat
FYI: Nismo Key
How to Adjust your Window Close Hieght
How to replace/install LED dash globes.
How to replace/install LED Climate Control globes.
How to remove and replace your air-conditioning filters.
Edited by GoldZilla
fixed links
  • Like 1
https://www.sau.com.au/forums/topic/102808-stagea-d-i-ys-how-tos-f-y-is/
  • 1 month later...
  • 2 months later...
  • 2 months later...
  • 2 months later...
  • 6 months later...
  • 7 months later...
  • 1 month later...
Has anyone done a r33 gtr frount end conversion. can you do it on any stageas. just wondering because i like the r33 gtr front better than all the others and i was going to get a 33gtr but the but i need a wagon for work and i cant get a towbar for the 33 to tow the trailer to go karting on the weekend. so a stageas my best option. however i want the 33 gtr front end. any suggestions?
  • 4 weeks later...
hello fellow owners. just gettn my first stagea its a 99 rs4 s and wondering what mods can be done to the neo engine with out spending mega bucks. (and f*kn it up) Im thinking maybee puting on a exhaust, front mount, bov and uping the psi a notch and then a good tune but this alone is costly. if anyone has done some budget mods and can help me out with some info that would be much appreciated.
  • 1 month later...
Hey guys/girls, i ve just picked up a pearl white 98 stagea and i am looking for touch up paint to fix a few little marks . Any help??? do the stegea paint colours match other nissans similar age like silvia's and skylines???
Yeah, you should be able ot find the paint code on your VIN plate under the bonnet. A Nissan dealer or any automotive paint shop should be able to provide some paint for touch-up use. If they don't have it, they should be able to mix it up without any hassles.
  • 8 months later...
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
