  • 1 month later...
Hey guys, Pom here.
Is there any info about draining and refilling the coolant system?
I seem to have some very nasty rusty looking water in my Stag and would like some info before i drop it all out.
Just how to refill and bleed the system would be great.
This site is brilliant for Stag info.
Cheers
Sy.
Hey guys, Pom here.
Cheers
Sy.
Here is a picture of the bleed valve - mine has a little tag on it that says "never open when hot(courtesy of SK):
Thank you :)
Is it just a case of taking the bottom hose off and draining it ?
I have seen the little cross headed screw thingy on the rad but after reading how they break then i'd rather take the hose off. I seem to have a little leak underneath the inlet manifold that's dripping onto the oil filter, Is there anything around there that's common for leaking ?
Also what kind of coolant to use ?
I got no service history or booklets with this car ( Big gamble huh !) So im literally flying blind at the mo.
Didn't stop me doing the high boost mod and chucking the Apexi filter on today though .. :P
  • 4 weeks later...
hey all i am new here have a rs4 97 had nothing but dramas since i bought it (not to the cars fault) had some drunk hit me in the rear 2400 for standard bar so the joy begain body kit (from monkey warehouse) all the prep that go's with it and then the fiting was bodgie after hours of work had to go with the best i could do was not happy and the the frount mount done with no effort at all and then the elec boost controller then was happy with the over all performance of the wgn even with the 4-5 coil pack miss unitl now was not that badthis is a family car if the idiot had not hit me it would still be stock execpt cat back. i have 9 month old twins and cant stand commodore's hance the stagea. the miss seems to be the coil packs i only run 7psi in it as i cant go any higher has any one fixed this prob with just new coil packs or do i just go and get fuel cut as well would like to run 10psi or higher (for when i am on my own) i am prepared so spendthe money for coil packs but that is it as it needs new suspension and need to save mu pennys
i would also like to thank everyone for this godly place would still be licking wounds if it was not for all the info found hear when ever i am in doubt i come STRAIGHT hear and find much comfort..
again many THANKZ to you all
will give my system a flush now
Coil packs are expensive. have you checkd your plugs? Get a set of coppers gapped to 0.8mm (NGK BCPR7ES-8 are pre-gapped). If that doesn't fix it try to borrow some coils before you fork out for new ones (Yellow jackets seem to be as good as the splitfires but cheaper).
As for the tuning get an Apexi SAFC (old cheap one will do) and if you can find one an SITC for the timing.
BTW if you do a search on coil packs you'll find lots of ideas for insulating them with tape or epoxy.
Well annually should be fine for plugs but sounds as though you may need coil.
SAFC is fo adjusting air/fuel ratios .. will overcome rich/retard (what you were referring to as fuel/boost cut.
Basic models are $100 -$200 there is a flash one with blue screen in the skyline parts for sale of this website
Google Apexi SAFC for more info
thanks heapswill ask my mate if he can get me one aswell as the coil's.....
are you born and breed in nz??
i am from kaitaia(though born in aussie so got the best of both worlds a convict and kiwi)
wife is from d'urville island.
the coil packs seem to bee the most common thing that stops boost is this right??
is this just because they are crap[ or is there a tech reason they cant handle boost??
will spend the rest of the night catchin up on SAFC
many thanx again
  • 5 months later...
I remember someone put some DIY intercooler cleaning but can't find it anywhere, think they had half and half mix of turpentine and metho from memory with a rinse of water at the end. I read on some other site people using vacuums to dry them out.
Yes its in the DIY sticky>intercoolers>>R34GTT i/c into stagea (and its kerosene and meths).
  • 11 months later...
Don't buy the rip off splitfires (yellow jackets/Just Jap/Red jackets etc) as they're a poor substitute. The voltage output is all over the show and the latency is very slow. They also don't seem to last to long either.
Origional or Splitfires.
Cheers
Justin
  • 1 month later...
  • 1 year later...
  • 4 weeks later...
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
