Id say due to the upgrade the address path has changed slightly.
Instead of being
http://www.skylinesaustralia.com/forums/SBC-ID-III-AVC-t62408.html
its now
http://www.skylinesaustralia.com/forums/topic/62408-sbc-id-iii-vs-avc-r/
A quick search should bring the new one up anyway until someone feels like adjusting all the links
Instead of being
http://www.skylinesa...AVC-t62408.html
its now
http://www.skylinesa...d-iii-vs-avc-r/
can you do it or does it have to be a moderator? I have no idea what you are talking about but it would be good to have all the info available again!
Just remember, we take no responsibility to what you do you your car.
GENERAL
Australian Stagea Part Dealers
External Stagea Web Links
Stagea Parts List
Stagea Dyno Results
GLOSSARY OF TERMS
The C34 Buyers Guide
What do I need to do to my car before a track day?
Getting It Off The Line
FYI: Insurance for your stagea
SERVICING
DIY: Stagea 5000km Service
FYI: Air Regulator Maintenance
DIY: RB25DET: Changing the Spark Plugs
DIY: Changing the Oxygen Sensor, Lambda Sensor, O2 sensor, etc etc etc.
ECU
FYI: Series 2 (R34) ECU pinouts
FYI: copgy Backs
M35 ECU Fault Codes
ENGINE
RB26DET Conversion Tutaorial
DIY: RB25DET High Boost mode with standard solenoid
DIY: Adj Camshaft Pulley & New Cam Belt
DIY: Stagea Air Deflector
DIY: Oil Cooler Installation
FYI: Aftermarket Fuel Rails( thanks to SK)
Updates On The Jun 2.7l Staj Build
FYI: Max Hp Out Of Standard Rb25
FYI: Max Power Out Of Neo
How To: RB26 conversion
DIY: 5min $5 Intake Pipe Mod For Your Stagea/skyline.
TURBO
TUTORIAL - Guide To Selecting The Right Turbo
FAQ: Stagea Turbo Upgrading
DYI: Jaycar Boost and Fuel Control
FAQ: Turbo Timer Install.
FYI: SBC ID III vs AVC-R
EXHAUST
FAQ: Stagea Exhaust
FAQ: Split Dump Pipe
INTERCOOLER
FAQ: Stagea Intercooler
DIY: R34GTT Intercooler into Stagea
DIY: Water Spray For Aftermarket Intercooler
FYI: Check Your L/h Inner Guard Intercooler Exit
FYI: Intake Temp Cooling Options.
TRANSMISSION + DIFF
C34 Stagea CV Joint (and Boot) removal/replacement (and part numbers)
FYI: Stagea gear ratio's
DIY: Transmission Cooler
FAQ: Automatic Trans Thread
FYI: Stagea Diff - Is It Wearing Out - Replace With?
FYI: out goes the stagea diff in goes the GTR diff
DIY: Running your Stagea in RWD mode
FYI: Manual Conversion Checklist
DIY: Auto to Manual Conversion Guide - SAU
FYI: Why NOT to convert auto to manual + some manul conversion info
DIY: Stagea Auto Troubleshooting
DIY: How to SAFELY convert your AWD Stagea to RWD (for dyno days, etc.)...
BRAKES + WHEELS
Stagea Brake FAQ
DIY: Anodize your brake calipers
DIY: How To Paint Your Standard Brake Calipers
DIY: Stop your brakes squealing 101
FAQ: Stagea Wheel Dimensions
DIY: Stagea brake upgrade using R33 GTSt calipers and discs.
DIY: Painting your wheels tutorial
BODY
Car Care Prescription (detailing)
FAQ: Stagea Body Kits
DIY: Front Bar Removal
FYI Front Glass Tint
FAQ: Replacement windscreens
Tow Bars for Stageas
FAQ: Insuring your Stagea
FAQ: Alarm for your Stagea
DIY: Rear Taillights
DIY: Headlight Bulb Replacement
Stagea Bonnet Gas Struts
INTERIOR
DIY: Stagea Headunit/stereo Removal
FAQ: Stagea Floormat
FYI: Nismo Key
How to Adjust your Window Close Hieght
How to replace/install LED dash globes.
How to replace/install LED Climate Control globes.
How to remove and replace your air-conditioning filters.
I need a beer after that
  • Like 1
hey none of techos links work they just go to the homw page , wtf
thats what the 6 previous posts to yours say...see my above post for the fixed links
there were 2 that i've removed as one was a duplicate and another i just couldn't get to work on an external site.
  • 1 month later...
  • 4 months later...
Hey there,
Excuse me if I missed it but do you have a tutorial on reseting TPS after cleaning the throttle body on a VQ25DET?
My Stagea is idling too low & cutting out on hard stops or (sometimes) during parking. I figured cleaning the throttle body & Idle Control would be a good start but I'm concerned I may not be able to reset the 'fly by wire' system. I have heard they can be a pain.
Cheers in advance!
Hi Lisa,
Yes, your on to the right direction. Other thing to look for is any vacuum leaks, letting in air to the plenum. You're correct that it can be a pain, best not touch the plate itself, just spray around it. I have no idea if it actually affects anything, but I'm careful opening it this way and that. You'll see a build up of black gunk on the back side of the plate, which causes it to stick and not come back to idle after decelleration.
Here is a link to the reset- timing is critical:
http://www.nicoclub.com/archives/g35-how-to-reset-ecu-throttle-pedal-release-idle-air-volume-learning.html
failing that- it can be reset using CONSULT III at a dealer.($)
Welcome to the site, and enjoy your stay :)
Thanks for the link. Awesome info to know!
I cleaned out the throttle body (without moving the butterfly) & what a difference. I now idle at 600RPM instead of 430RPM & the pick up is MUCH better. No stalling either (yet...touch wood).
Cheers for the welcome :)
  • 7 months later...
Hi everyone,
I've got a Nissan Stagea 250 RX Four and the brake light atop the tailgate is not lighting when brakes are applied. Does anyone know how to replace the bulb if it has failed, or otherwise remove the entire unit if it needs replacing?
Thanks in advance for some assistance
  • 6 months later...
Considering the RWD M35's aren't allowed into the country in Australia, I doubt there would be much info floating about. I would say it's very close in most aspects to the G35 in the states. What info were you after exactly Garry?
Except for vq35de ones :P
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
