Hi i was wondering if ne one else has come across this problem, when i start the car, theres a clicking sound that goes, click click clik abotu 5-7 times coming from where the windscreen vent is. It stops after this and the air con and everythign works fine, its got me puzzled? Anybody aware of this problem???
https://www.sau.com.au/forums/topic/102812-clicking-sound-on-r33/
It's kinda weird, my car has had a manual conversion, but the power is still to the old automatic switch, they one that sawy att or power w/e and snow, obviously this is disconected but there still current to it so when you switch it, the switch will light up, the power light allthough switch isn't on, flashes intime with the clicking sound, and stops right after. Hmmmm as you guys said its not a problem the car runs find i just find it odd it flicks???
I this a probelm you guys have found becuase yoru converted a auto to a manual, or were you cars allready MT's?
Just a though Michael
According to a post by someone (can't remember who) they found the clicking to be gears in the climate control playing up. The photo is one that they posted up. I seem to remember them saying it took 6-7 hours to get to it properly as you have to pull the whole dash out (speedo, vents, etc.)
exactly right ian, but it will take someone thats good with tools under an hour to get to it. my car is off the road atm so ill give it a go. ill post up pics on how to fix it.
im into fixing things without replacing them (unless it will be deemed unsafe). ive got a blower missing a gear so ive got to get in there anyway.
keep an eye out.
AFAIK, there's two air doors (I've got this problem too and I've read the original post where someone fixed it...)
First is the face/feet/screen door, second is the air con/external air adjust. My understanding is there's either a cog that allows it to recognise when it's reached the end of travel, or there's a little microswitch in there to do it. (There is definately a cog - this is what makes the "click, click".)
The air door(s) get to the end of their travel and the motor keeps trying to turn it, hence the click. Mine does it on startup, changing certain vents (face to feet, I think), and at certain temperature changes (which I why I think the air con/external air door, at least on mine, is causing the problem too...)
Not a major problem, just a nylon gear going "click", but it is an annoyance.. Apparantly the part to fix it is around $5 from Nissan, it's just a bugger disassembling your whole dash to get to this one little part!
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
