Hi i was wondering if ne one else has come across this problem, when i start the car, theres a clicking sound that goes, click click clik abotu 5-7 times coming from where the windscreen vent is. It stops after this and the air con and everythign works fine, its got me puzzled? Anybody aware of this problem???
https://www.sau.com.au/forums/topic/102812-clicking-sound-on-r33/
It's kinda weird, my car has had a manual conversion, but the power is still to the old automatic switch, they one that sawy att or power w/e and snow, obviously this is disconected but there still current to it so when you switch it, the switch will light up, the power light allthough switch isn't on, flashes intime with the clicking sound, and stops right after. Hmmmm as you guys said its not a problem the car runs find i just find it odd it flicks???
I this a probelm you guys have found becuase yoru converted a auto to a manual, or were you cars allready MT's?
Just a though Michael
According to a post by someone (can't remember who) they found the clicking to be gears in the climate control playing up. The photo is one that they posted up. I seem to remember them saying it took 6-7 hours to get to it properly as you have to pull the whole dash out (speedo, vents, etc.)
exactly right ian, but it will take someone thats good with tools under an hour to get to it. my car is off the road atm so ill give it a go. ill post up pics on how to fix it.
im into fixing things without replacing them (unless it will be deemed unsafe). ive got a blower missing a gear so ive got to get in there anyway.
keep an eye out.
AFAIK, there's two air doors (I've got this problem too and I've read the original post where someone fixed it...)
First is the face/feet/screen door, second is the air con/external air adjust. My understanding is there's either a cog that allows it to recognise when it's reached the end of travel, or there's a little microswitch in there to do it. (There is definately a cog - this is what makes the "click, click".)
The air door(s) get to the end of their travel and the motor keeps trying to turn it, hence the click. Mine does it on startup, changing certain vents (face to feet, I think), and at certain temperature changes (which I why I think the air con/external air door, at least on mine, is causing the problem too...)
Not a major problem, just a nylon gear going "click", but it is an annoyance.. Apparantly the part to fix it is around $5 from Nissan, it's just a bugger disassembling your whole dash to get to this one little part!
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
    • Welcome.  Here's what I have noticed about forum vs FB..... FB; seems to be wallet racing, and the same few questions asked over and over. There *may* be some groups that are closer knit, but most have changed for the worse. SAU; unfortunately, no longer in its glory days. But....genuine people with similar interests. Not all about how much you spent and saying you dont have enough power. Sooooooo much knowledge available. Have personally seen people post up about literally topics I made myself, asking on FB like no one has done it before. Most has been done, and most of that is here.   If you ever feel like just general chatting theres the wasteland.  Other interests are also generally covered in other areas of the forum. Hope you enjoy hanging around. We would love to have you.   P.s. nice 32 😀
