Hi everyone
Selling my car due to needing the money :P
Description:
1995 m-spec gts-t
black
93000 kms
REG till 26 May 2006
Always serviced regularly (still has log books etc from Japan)
All belts were replaced at 85000kms
body is in very very good condition
lowered 1.5 inches all round
18" chrome wheels and tyres (practically brand new)
3" mandrel bent cat-back exhaust with highflow cat and stainless cannon style muffler with epa noise print out at only 85 DB (well under legal limit)
new plugs, timing tune and boost increased slightly to 10 p.s.i (done by RX engineering and dyno print out)
Blitz pod filter
apexi turbo timer
Boost guage (custom installed wher ashtray usually is)
cd player
fusion 3" speekers all round
Interior is pretty much immaculate (slight wear on handbrake boot but hardly noticable)
Factory skyline floor mats
Car is in all round great condition, a definate head turner and very reliabe (it took me 3 months to find this car in this condition and ive owned 2 r33's before this and it is in much better condition than the last 2 and drives alot smoother and quicker even with minor mods)
Looking for $17500
(im in N.S.W near Newcastle)
Can take pics on request
Also have the standard airbox and filter, springs and exhaust to go with the car.
e this as a guide for new threads. Delete and/or copy the fields as needed - dont
Contact me on 0422642319 or email [email protected]
https://www.sau.com.au/forums/topic/102830-fs-1995-r33-gts-t/
Hi everyone
Selling my car due to needing the money  :D
Description:
1995 m-spec gts-t
black
93000 kms
Blitz pod filter
apexi turbo timer
cd player
Looking for $17500
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
