hey guys.. i recently got rid of my STi Version 5 Type R. and im thinkin of getting a R32 Skyline GTS-4. do these cars have good potential/good response.. basically is it a good overall package. Cheers Sedat!
Ive been looking at this :
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/
i had a car accident, and i got paid out from my insurance. So are these puppies any good? are they in the same class as WRX. if i buy one im finking of doing a RB25DET engine conversion. i also used to own a VL Turbo before my STi. nice cars ;)
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/#findComment-1890435
they are ok they are basically a gtr with an rb20 instead of rb26. Check out just car insurance they are pretty reasonable with prices for performance cars. Im 18 and only paying 2100 a year on a r33 gts-t. So its worth looking into for a gtr unless you have a really shitty driver history?
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/#findComment-1890499
my driver history and all that is sweet, my friend was going to buy a R32 GTR and just cars told him that full cover insurance will be 9k a year!?? can this bee? are there any modded or unmodded R32 GTR owners dat pay 9k?
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/#findComment-1890527
hmm so what does insurance cost on R32 GTR's?? 2-4K?.. do any of you guys know a site where i can get all the details (engine/gearbox/1/4times etccc) on the R32 GTS-4. Ive heard that the GTS-4 uses the same gearbox and 4wd system as the R32 GTR
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/#findComment-1890591
Like said above; the 2L will be pretty sluggish. Mate of mine bought one, and gave me a drive. It had the usual mods, but it was pretty laggy and slow. Handled like a dream though, and he did some wicked stuff on skidpan days.
He has an R32 GTR now, and there's absolutely nothing that it's missing. Goes like the clappers, and it's stock!
Call Just Car, and get a quote. I'm sure it's not going to be 9K. A quote for HALF of that would make me frown!
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/#findComment-1891108
:D dam I was told by them that they wouldn't insure anyone under 21 for turbos, unless you are a nominated driver?
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/#findComment-1894495
i can afford a GTR R32 or R33, but they cost to much to run and the insurancee they just rape you! i was paying 4k for the insurance the STi
And you think a different Skyline coupe, with a turbo engine conversion no less, is somehow going to be significantly cheaper?
How much do you think insurance on an Impreza GX would be after you did an EJ20T conversion on it? Or your running costs?
Be a man. If you want a 4WD turbo Skyline and you can afford it, get a GT-R. Don't arse about.
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/#findComment-1895580
i'll just say. having a 32 gtr and gtst, i can tell you it is very hard to get decent power out of a 32 gtst. if your happy with 200 kw at the wheels go the gtst, if you are going to want more than that don't buy one.
If you still want a 32 but going to fill it with 33 bits to get more power y not just buy a 33??????
Edited by RRR32_GoDzIlLa
https://www.sau.com.au/forums/topic/102904-hey-guys-im-new/#findComment-1897208
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
