Settle down Dan.........Just because yours made some rediculous amount of power. Just you wait till i wind in more boost lol.......I am looking for that almighty HIT when it comes onto boost :) I want crazy wheelspin.
PS: when am i gonna see that barge of yours out on the track sideways :P
https://www.sau.com.au/forums/topic/102935-drdrift-results/#findComment-1892214
You probably won't see it on the track sideways. I don't like to track my car unless I have alternative means of transport....for instance if I were to buy a newer car I would then use the old one for track work. It's either that or do up a 180 with a ca18 in it....pull it apart, bom the crapper out of it and see how she goes. Good thing I can buy turbos cheap....might put a set of twins on it, what do ya reckon?
https://www.sau.com.au/forums/topic/102935-drdrift-results/#findComment-1892230
212rwkw is awsome....
Nice
PS. Do u still need that heat shield???
Heh, col you are such a good man. PM me what days you have off and well see what we can work out. I was looking at my missing heat shield before :D
Ive also posted up a dyno chart in Forced Induction Performance section.
https://www.sau.com.au/forums/topic/102935-drdrift-results/#findComment-1894244
hey dan, what are you running in your car? have you taken it down the 1/4 before?
Goto http://www.oznissan.com/board/index.php?showtopic=16
I couldn't be bothered listing everything.
Haven't been down the quarter yet but will be soon. Hoping to get it into the 11's but gotta sort out some issues first
https://www.sau.com.au/forums/topic/102935-drdrift-results/#findComment-1894848
Riverside - What turbo are you running on your CA? Sam tuned my car when he was in Brisbane last year, it made 175rwkw on 14psi runnig a VG30 roller bearing turbo, this was befroe he had his real time tuning.
I have just fitted a GT28RS turbo and am looking for a power figure similar to yours.
https://www.sau.com.au/forums/topic/102935-drdrift-results/#findComment-1895205
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
