  YCA18T said:
Riverside - What turbo are you running on your CA? Sam tuned my car when he was in Brisbane last year, it made 175rwkw on 14psi runnig a VG30 roller bearing turbo, this was befroe he had his real time tuning.
I have just fitted a GT28RS turbo and am looking for a power figure similar to yours.
He's running a GT2871 with the 0.86 rear which is rated at 440hp :)
That was NOTHING!!! Last time I was there we had 2 blown oil seals on turbos, 2 faulty fuel pumps, a water pump snapped on the dyno, a dodgy CA with forgies where the engine builder left the comp too high, leaking injectors, and probably other less significant problems... no to mention it was a consistent 12 degrees warmer last time...
So was my car the only one the first time around (in Brisbane) that didn't have any major problems on the dyno, apart from the turbo not holding boost (Well that is fixed now with the new turbo, holds 15psi from 3400rpm to the limiter).
Although i did have issues after the dyno tune with a broken tailshaft at the drags, maybe to much power :lol: or just a crap tailshaft.
