hey, can someone please tell me if they know what this vehicle module is or what it does.
it is located behind the rear seat somewhat in line with the parcel shelf within a bracket. i removed it from my sII r33 and car does not seem to have any probs...just wondering if anyone knows what it is for and what it does.
thanks heaps.
- Ross
https://www.sau.com.au/forums/topic/102936-unknown-module-r33/
lol.. you just removed it? I found mine when I made a new parcel shelf recently.... No idea hey!? Can you read a part number off it? I forgot to write it down. I was going to look it up in FAST to see what it is!
FAST is the Nissan parts database. It's a 1.5Gb download via a torrent and it installs as a 5Gb(ish) monster. It has part listings and part diagrams for all models of Nissans.
If you see guys asking for a FAST lookup for a particular Japanese VIN, it is because you can enter the VIN and FAST will display the vehicle data that corresponds. Handy for checking original colours and trim plus checking for auto->manual conversions as well.
After a quick look it's actually a 2.5Gb monster.
If you're on dialup, PM me your address and I'll burn it onto DVD+R for you dude. But then you'll be obliged to help guys that ask for help! :)
Let me know. I don't have the .torrent anymore so can't help with that :)
Is there a link where you can download it from??? Huge file, but i can download it through the night. I aussume torrent is a dowloading sharing network???? I'm not sure??
THanks Michael
Edited by Michael_1882
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
