Morning all,
I just got my power fc today. woo hoo!!! but was surprised at the lack of wiring. infact all thats there is the cable coming off the hand controller. i realise that the unit plugs into the standard loom but i was expecting a cable or something so the unit car sit in the car (passenger floor) is this all thats spose to be in the package???
https://www.sau.com.au/forums/topic/102950-just-got-power-fc/
I found the ap pfc to have much better idle control over the std ecu. :(
Overall it feels smoother to drive. Strange sensation really. :(
Now all you need to future proof your mods is a well priced bran spankin new Z32 afm. :D lol
Edited by Cubes
yeah i want to buy one like right now, but i have absolutely no idea were to get one from. its like NOBODY has one for sale. especially in pretty yellow writing which renders me incapable of saying no. but oh well. maybe one day. hehe
im telling ya, u havent lived until you've seen this key ring. as soon as i put it on my key chain 3 lesbian couples appeared on my doorstep wanting to group experiment. and being the nice kinda guy i am i had to help them out. true story. :(
It will run fine.
The AP PFC does require a little tweaking of the cranking ms.
From memory the std values are:
80c - 4ms
50c - 8ms
They need to be the same as the rb26 and rb25 values.
being...
80c - 10ms
50c - 13ms
The values below are the same for both the r32 and r33/gtr.
I found it started fine, then pulled over turned the car off and the darn thing wouldn't start, just kicked over and over and over.
Dialed in the rb25/rb26 injector crank ms for 50degree's and 80degree's and it starts first pop every time.
The ap pfc base map will run richon the rb20det, the ign. timing isn't over the top so it shouldn't ping, obviously depending on mods and amount of boost run through what turbo. :(
Its all very easy.. don't be scared to play, be carefull, not stupid.
Don't fiddle with afr's unless you are running a wideband..
Edited by Cubes
well i just bought an Apexi AVC-r today as im wanting to dial up 12PSI. and along with 3" turbo back zorst, Greddy FMIC, n POD i thought it might be an idea to get the entire thing tuned properly. I've been talking to a dood at UNIGROUP near sydney i think?? hope he does a good job. will be about 2weeks until the AVC-r arrives tho. so a small wait.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
