Hello from London UK :)
Been reading this forum for the last couple of days, simply because you guys seem to be the only souce of Cefiro info in the WHOLE of cyberspace. Im a member of www.driftworks.co.uk which is the UK's main drift comunity. I have just bought an A31 Cefiro and wondered if you guys could offer me some information?
I have also just bought myself another R33gtst which was unfortunatly involved in a nasty accident :P However the running geat and engine are straight so I was planning on swapping the engine and box into a ceffy. I can't see this being massivly difficult but if anybody knows of someone who has done it. I would love to speak to them before hand!
Questions:
Are the R32 and A31 rear subframe & suspension components the same?
Am I right in thinking S13 coilovers will fit the A31?
I know that R32 rear strutbraces will fit the A31 but what about front? Nobody over here stocks aftermarket items for the A31 and I was wondering if they where the same as S13 items.
My car runs an RB20E engine on an automatic box... Which is a bit crap but i bought the car for the shell (which is really tidy) rather than the engine (which is shat) Does anybody know what diffs these cars run? Are they standard open diffs? or do they have an LSD.
Thanks in advance folks!
and HELLO!
Chris
https://www.sau.com.au/forums/topic/102975-hello-from-the-uk/
Greetings. congratulations on buying a good car
most footwork (suspension etc) will come out of the S13,
the RB25 will fit into the engine bay, as will all other running gear
i dunno about front strutbraces
if you look inside the centre console between the two seats there is a gold sticker which tells you whether or not you have a viscous LSD which are shat anway, enjoy!
The R33 running gear won't bolt straight up to the Cefiro though will it?
It was my understanding that the A31 was built on the S13/R32/Z32 floorpan and the R33/R34/S14/S15 etc were all built on a compleatly different one. VLSD's are not as shit as people make out ya know.
Fresh R33 VLSD's do lockup quite nicely with a kick in 2nd gear :) However it's not exactly advisable to lift off while sliding :) If it has an open diff, i will weld in in the short term then buy something like a Kaaz 2way or something.
Im only setting the car up as my "Road Car" as the S14 (that I use to compete in some of the drift series over here) has grown a little bit too extream for everyday road use :P
Thanks for the information folks!
Chris
Edited by Guishnu
we just used the front and rear hubs of an R33 GTSt to do a 5 stud conversion on a ceffy. We also swapped the RB25DET, gearbox, wiring loom, ECU, power steering pump, rack, alternator, brakes, and brake booster into the A31 (coincidentally also an RB20E auto model). So its mostly compatible. Suspension struts/coilovers are more compatible with the S13. Diff was the same as an R32... or maybe it was an S13... i'm not actually sure on that one, we used a mechanical 1.5 way in any case. A viscous LSD will only last you so long, but if its for regular street use and not track use, then it'll be fine.
A31 strutbraces can be bought out of thailand/malaysia pretty cheaply, they're decent quality too (or you can get em from australia, either way you'll get stung with shipping though). You can't fit R32 strutbraces onto an A31, because the R32 ones are 2 bolt and the A31's are 3 bolt. Your best bet would be an adjustable S13 brace (3 bolt), as the distance between the towers of the S13 and A31 are slightly different.
I have an Rb25 Powered Ceffy that is, when money and time off work permitting gets drifted.
Heres some drivetrain stuff that I don't think was mentioned.
Ceffies use an S13 cradle for the diff, If your going to chase power or dori the car get an R200 diff from an S13 or S14, it will bolt straight in and has 5 stud drive shafts which will handle alot better than the standard 4 stud stockers - this being said I did shatter the 5 bolts on my left hand drive shaft and make a mess of it yesterday.
The drive shafts from an S13 fit. Which makes parts easy to get hence my car is back on the road as of lunchtime today so shattering the driveshaft wasn't the end of the world.
Go the 5 stud R32 Hub conversion, Im sure there is threads buried here about it, its very easy to do all bolt on stuff, but on the rear youll have to bend and cut the drum metal shrouding stuff... Hard to explain but as far as I know its doesn't come off...
Thats my 2 cents on driveline stuff, its good to upgrade it all it will save some headaches and isn't very expensive to do.
As for engines... Go an RB26
"Well why not? If anythings worth doing, its worth doing right" -Raoul Duke, fear and Loathing In las Vegas
Edited by BasketCase
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
