SUNDAY 16/02 Cruise and BBQ Homebush-Kellyville-Bobbin Head (Replacing Track day)
Majanal
 Share
  • Replies 173
Count me in just hope i got my car back
getting a service, injector clean, throttle body clean, dual stage boost contoller, and a bleed valve and tuned on the dino all done in the next 2 days just hope its ready for sunday.
So at this point i will be there
wooooooooo
Just to throw a (late) alternative, I just heard from the Honda club that the Catalina circuit at Katoomba is having an open day on Sunday. This tracks been closed for about 30 years, but still exists and will be open (not for driving :D ).
So, should be consider this instead? We could head up there for the morning and then move on to a BBQ somewhere in the area.
if i remember correctly there is a coval about 30m diameter at the end of bobin heads with a tap in the middle.
if someone brought a hosse we could have some real fun round that circle..... bugger it we can do it in the dry.
wait a second ive just checked the rule books apparently it very illegal to do this, and the head people of SAU dont encorage this
shit
im there but ill bring some rods and catch me a tuna
pete
ps and watch out for bike rides on the way in ive almost hit 40000 of them
Finalised Route:
Homebush Carpark 6C 9-9.30 for 10 am departure -> Silverwater Road -> Victoria Road -> James Ruse Drive -> Old Windsor Road -> Maccas, Windsor Rd Kellyville at 10.45 for 11 am departure -> then cross country to Galston Gorge -> KU Ring Gai Chase Road -> Bobbin Head
We will have a meeting point along the route at Maccas, Windsor Road Kellyville.
This should put us at Bobbin Head around 11.45. If anyone wants to go straight there please do by all means (and reserve some spots :)).
:)Bobbin Head info
Hey all i would love to come along to this event but i am gonna have to be relying on being a passanger seat whore as my car is....um how do i put this..."F$%KED UP or F.U.B.A.R.'ed"
So Nick (By By) is it possible to jump into ur passanger seat for this event! I will give you a call and run it by you tomoz!!!
Cheers
Ando
I hope to make this BBQ, but I've got plans the night before and I'll be crashing at someone's house down south, so I'm not sure I'll get to Homebush by 10am...
If I don't wake up too late, I'll meet you guys at the BBQ spot :P
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
