Hi all,
Getting on the track for the first time next month, got a couple of questions
What sort of helmet is best?? I would think open faced, and they need to be ADR approved right? and motorbike style helmets, just they'res some nice open surfing helmets etc.. on ebay. Where do you buy them from?? any other places than motobike shops (who charge an arm and a leg).
was thinking something like this:
http://cgi.ebay.com.au/Excellent-Black-ARA...1QQcmdZViewItem
Searched for tyre pressure and could only find one post where they said 40psi is best - i have hankook k104 235/45/18s on the front and falken ziex (yes crap i know) 265/35/18s on the back.
Any other advice for a track noob??
(I posted this in the club motorsport section but seems pretty quiet there, apologies to mods for crossposting)
https://www.sau.com.au/forums/topic/103020-first-time-trackday/
I bought mine from cash converters for $40. It has the correct AS standard rating. They usually have a few at cheap prices. But I can understand if you would want to buy a new one, but it will cost you.
Just check all your fluids.. most importantly coolant and brake fluid.
It would depend on your tyres as to what pressure. For ze326, they are crap like you say, so it won't matter too much.
I tend to run 32psi cold.. which equates to a few psi above that warm. Seems to work for me.
As far as helmets go - the best you can get for the money you want to spend. Lets face it, you wear it in case of a crash - a sh1t helmet will give you sh1t protection. That being the case, I know we all buy budget. Try the likes of Tyretech and Revolution. Both have good cheap helmets.
As far as tyre pressures goes, people would have recommended around 40psi because it is safest. Probably not the best for performance, but it ensures that if you hit a ripple strip sideways, it is not going to peel the tyre off the rim and flip the car. Once you are more comfortable with the track work, you can probably start reducing pressures to suit the conditions.
As Predators said, fluids are important. Keep them cool and always make sure you have pressure (especially oil).
With the temperatures these days, there is a fair chance you may run out of brakes - they tend to boil fairly quickly. If they start feeling doughy, be real careful. All of a sudden they can just dissappear completely.
I always use an octane booster for detonation protection on the track. Wspecially if its going to be fairly hot.
Best advice is to start slow and build up. Nerves usually make you go like a scalded cat right from the get go, but just pace yourself at around 75% of what you feel you can do, then build it up.
You only need one fast lap to count.
Have fun.
All that has been said is spot on and some more things to remember are that when you are doing your cool-down lap and while coming into the pits, stay as alert as you were at speed cause I've seen a few people come off / crash during a cool-down session. Also remember to NOT apply your handbrake when parked in the pits :) As soon as you get there, look around for a brick or large rock to chock your tyre so the car won't move.
IMO, and experienced,
Invest ur money into a decent helmet, trail and test for the 1 that fits and comfortable.
As u dont want to spend most of ur time on the tracks feeling uncomfortable, and where in emergency, it save life, beter than 2nd hands, sometime they not.
Your brakes will still be hot when you come off, even with a cool-down lap.
If you pull the handbrake (especially on Nissans that tend to use the caliper rather than a separate drum), all the heat from the rotor gets transferred through your pads.
Problems I've heard range from the pad fusing to the rotor to the heat boiling your fluid and damaging it.
A surfer's helmet will not cut it. For private track days, where they don't really scrutineer, if a surfy helmet looks like a car/bike one you might get away with it. But if anyone checks, you won't be allowed out.
Of course, in case of an accident you may as well not be wearing it.
At a startup level there's not much in it between open and closed face. Open face will keep some body temps down since its not trapping your breath, but to be honest you won't notice it. I personally don't like open face helmets, but if rally drivers can get away with it then it can't be all bad.
As people have said, keep an eye on your gauges. If stuff runs outside of its normal parameters, back off. Give it a lap or two to cool down. If my car goes a bit weird, I'll use half throttle and short shift on the straights, and gently brake a second or two early so I can take the corners slower.
Which leads me on to my next point. For the love of God check your mirrors! And if someone catches you, find somewhere safe to let them pass. You're not racing for position, so if people go to pass you don't take it as some insult to your manhood and try something heroic.
There's nothing more frustrating on the road than getting stuck behind some slow poke who decides to baulk you - the track is no different.
Being passed does not make you look like a dickhead; running off the road or blowing something up and needing to be towed off will. Everyone will get pulled off the circuit and they'll line the pit wall to watch the tow truck come out and get you, knowing they're losing valuable track time because of you. :)
You can also get cheapish new helmets from bike stores these days. They're missing most of the vinyl rice that the expensive ones come with, but I'm pretty sure some guys have picked up new helmets for $200-$300. Which is not unreasonable.
Thanks for the advice everyone :D
Never thought about the handbrake, guess i'll bring a wheel chock and leave the car in gear in the pits...
Everything else i already put down to common sense.
Damn $300 for a helmet, was hoping i could get one cheaper than that.. ah well Wanting to get open faced cos i would have thought it would be easier to see out of (and the temperature thing as someone mentioned).
Apart from the wheels my cars got tanabe coilovers, strut brace, slotted dba discs on the front, dba ultimate pads front / premium rears, short shifter, r34GTT intercooler, 10psi and around 170rwkw. Not intending to push it too hard as its the only car i got :(
One other thing- obvioulsy it would be stupid to drive with the a/c on but i'm pretty sure most still drive with the windows up (unless drifting with one hand hanging out lol).. is that correct?? must get hot in there :lol:
A lot of pit areas will be flat because they know its an issue, but bring your own bricks just in case. I use the space saver tyre. :D On a related (heat) note, it shouldn't be an issue on most tracks but don't park your car on the grass. While unlikely, there's still an off chance you could start a fire.
A modern closed face helmet will not block your vision appreciably, and definitely not in areas you care about. Left and right, the opaque parts start outside of your peripheral vision so you don't lose anything there. Top and bottom might be blocked off a little, but that just means you can't see your roof lining and the logo on your steering wheel.
I will normally drive with the windows down so I can hear the wind and engine noise better. While it does mess with your aerodynamics and means you might go a little slower, I don't think most of us are quick enough to notice in lap times.
The only time I've ever wound the windows up is for the main straight of Eastern Creek. I'm not sure if it was just because I was trying and braking later or because of the improved Cd, but I did pull an extra 5km/hr top speed.
But if the difference between window up and window down is from 197km/hr to 203km/hr on the longest straight on a NSW track (that's also downhill), I'll keep my window down and my ventilation up. I also keep the visor up on my helmet, so I get some flow onto my face.
The rule on the race tracks I've driven on (the Creek, Wakefield and Oran) is the window is either entirely up or entirely down. Wakefield insists that if you're carrying a passenger on one of their private days, their window has to be up (the driver's can be down).
You'll generally only be sprint racing, or maybe doing a 15 minute practice session. Cabin temps should not an issue, especially since you're not wearing the 4 layers of fireproof suit that pro racers do. You could always go out with the windows up and try and do some hot laps, and the wind them back down when you do some cool-down laps.
Edited by scathing
Can somebody tell me why some people race with the heater on full blast?
Because they're insane? ;)
Some cars don't have dedicated heater elements for HVAC. They just filter air from the engine bay when you ask for heat. So some people turn the heater up full blast to help cool the engine bay down.
You'd be best off finding out how your car's HVAC obtains hot air before considering it yourself.
I always run with the window down. Helps me stay cool, and allows easy hand signals to other drivers if they want to pass me.
Get the best helmet you can afford - it's your head, after all. And really, the cost is almost irrelevant - over the life of the helmet. you will spend much more on mods, maintenance, entry fees, fuel.
Wouldn't bathursts conrod straight be longer ;)
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
