  • Replies 717
Ok. Just a quick note: TURBOSMART will be sponsoring this day with a few new products as prizes for selected categories. Prizes to be as follows:
TURBOSMART T-REG PRO fuel pressure regulator. Valued at $349.00
TURBOSMART FCD3 fuel cut defender designed especially for liners running mods with std ECUs. Valued at $229.95
and
2x TURBOSMART 2pc OILCAPS (blue anodised). Valued at $74.95 ea
See you all there!
Running a dyno correctly means this isn't even close to true.
WHY?
how can you control the temp that the car draws in???
so if i put my car on a dyno on a 35 degree day ill have the same power output when i get a dyno on a 15 degree
winters day "as long as its running correctly!!!!!!!!!!!!!!!!!"
No, you'll obviously have more power on a cold day at the tyres.
A properly run dyno running properly set up temperature compensation knows this and will correct the values so they appear to be the same.
Dyno Dynamics software shows these corrections along the bottom of the screen.
Edited for typo
Edited by MattSR
just another thing, i know you can adjust dyno temp to allow for the higher intake temp, but turbo cars always run better in cooler temps, so unless the dyno can adjust so it allows for EXACTLY how much power you lose on a hot day, you will always make more power a cold day.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
