Sau Nsw Dyno Day
Abo Bob
  • Replies 717
I'm sure Abo bob will post the results for all catagories,
but Boosted Zed squeezed out 427 rwkw from his VG30DETT,
go the cardigan wearing, tea sippers . :/
Sorry Mona, got there after 1.00, had to work.
You had a little scare, 500+ ?
See you @ WSID
Just had a look at Stan's dyno graph - from the SATANIC. Very surprising to see that UAS backed off the run before it even ended... meant that peak power wasn't even reached??? The dyno graph just went vertically downwards at the end, power curve hadn't even started to dip yet.
Anyone else see this on their graphs or was it just Stan's?
If I recall his A/F ratios were running a little to lean to push it too much farther.. was a good run.. could have held on a little longer, got a video of it here.. I think the main issue with power was his boost dropping off 1psi..
anyways.. good day.. stuck round for a bit.. than left.. stupid whining gearbox.. shits me to tears now sounds like i'm running a dogbox or something..
you the guy with the white shirt and camera? LOL!!! any vids of my car?!?! :/
Did anyone happen to get a vid of my run?? If someone did i would like to get it. 177.1 with a stock computer wasnt bad, and the induction scream nearly gave me a hard on!!
Who had the RB20 GTS-t with STD turbo Stock ECU and heaps of powa....smoky or what??
sorry to dissapoint.. but wasn't me mona.. I was hiding away.. nah had a singlet on.. not sure who else was there with a camera..
top secret anyone..
nice turn out of cars..
Edited by Links
yer morgs made 365rwkws with 19psi. Top secret car was a little disapointing made 440rwkws i think but had a t88-38k and 25psi i think thought it would pull more then that.
And where was duncun with BBQ :/
:sorcerer: Brad
I had a white T shirt and a camera... I was the one that wolf whistled back at your car Moanie :/
Pics coming soon...
Actually, thats me in the right hand side of the pic of the Top Secret GT-R lol!!
Edited by MattSR
Yeah great day in my opinion... nice area, plenty of parking (even if it was a bit tight) and overall very well organized! Well done to Adam :D
Personally I was a bit disappointed at my own result, not so much the number of rwkw's generated but the fact that I was running 1psi off from the tuning 2 weeks ago @ HITMAN. Also, I'm still wondering why they backed off the throttle at that specific rpm - definitely wasn't rev-cut. On a good note, I got a torque graph out of it :D very torquey setup :/
However, just like last time - I've come home with new ambitions (oh my god here we go again)... we've re-routed the boost lines and we're now currently holding 13psi flat :) Dunno if it'll be stable, need to get it dynoed again soon or maybe I'll just wait for the Haltech.
Great chatting with old mates, new mates and most of all seeing the turnout to this event!
I was told Mik made 371rwkw @ 1.5bar (22psi)?
maybe Mik can post and let us know
Mik made 371kw. Boost is typically 1.45 bar.
Thanks to Adam for organising and John for running. Also, thanks to Ben for finally listening to me and strapping it down... :/
yeah he got 265rwkw with nos, between 4000 and 4200 rpm he went from 120rwkw to 235 rwkw!!!! Near vert curve. Crazy.
It only took that long as I asked Ben from UAS to ramp it slowly to 4400rpm then bury it :/ Not a great idea ramping from low rpm with nitrous on a dyno under load. Rods don't like it. lol
I was happy with the 190kW no gas - I hope anyone who watched the curve or saw the power vs. manifold pressure graph took note of the values. If there are any old pricks with something to say purely for the sake of saying something still talking i'd be surprised.
Thanks to Adam, Turbosmart and UAS for a great day.
Adrian
Adrian
Im an old prick...but have noting but congrats to all the winners!!!
    • Time for millspec wiring, MoTec electronics package, Bosch Motorsport ABS, let's goooooooo!!!   Maybe as @MBS206 suggested, just swap out those stupid blue relays near the ECU plug.
    • My only regret with the NC MX5 was no space for a spare, even a space saver doesn't fit in I do have a couple of those puncture repair spray cans, but if I get a large puncture, or sidewall damage, I'm screwed until a tilt tray turns up I'm thinking I might get one of those 4WD style of puncture repair kits that have that rope stuff and glue, whilst it will kill any hope of saving a tyre, it might help getting me out from some backwoods road far enough to find a actual tyre shop if the first can of tyre fix doesn't work I'm keen to see how your new toy pans out Uncle Duncan, I'll be moving to the Highlands next year, you'll need to shout out if your heading to Wakefield, whilst I've lost my balls for happy laps, I still love watching those that can
    • Yeah not sure what the warranty was, but it will be years outside it.  I've shot Link a message, will see what happens, I'm told their support is good. It is a plug in, so its a Link board in a factory case, very easy to access both sides of the circuit board by removing the top or bottom cover. To be fair the the Link, although I've checked to the factory connections and wiring specs, as we learned with Neil's car in the early days not all ECUs source power the same way. He'd been running a factory ECU with no trouble for years, but when we plugged a PowerFC in it wouldn't start up, just kept cycling power on and off. We worked out that the car was missing one of the 10a fuses "Electronic Parts", and to Neil's knowledge it had never been there. Turns out the ECU pulled its main power from that source not the same place the factory ECU did.  Point being....there are multiple battery and ECCS power sources in the factory ECU, and multiple grounds as well....not telling from the outside exactly what the Link uses (and doesn't use)
    • Now, thanks to sonicii, onto the uneven floor from a tyre sticking 100mm into the boot space. I looked into options to raise the floor to the level of the tyre, and ended up going Extruded Polystyrene (XPS). EPS is what I normally think of as polystyrene, the annoying tiny balls that get glued into a flat sheet but XPS is quite different, much firmer and doesn't crumble if you touch it with anything. I also looked at things like heavy duty seating foam but XPS seemed like the right way. I picked up 3x 1200x600x50 sheets for $40ea. Initially I was looking for 100mm sheets because I needed to make up a 100mm gap, but as it turned out 50mm was available, much easier to work with and made it simple to store the tools I used a simple 15cm foam cutter to make the shapes. With some practice I was able to make reasonably clean cuts but I don't think Clark Rubber are going to be calling me to offer a job. https://www.ebay.com.au/itm/405092315205?var=675175481574 First layer in place, 3 dimensions are tricky! Second layer in place, bringing it to level with the top of the spare Cutouts in the top layer for the tools With floor back in place, nice and flat with 100mm stolen but no real impact on usability
    • Sounds like a good idea to me moh
