Sau Nsw Dyno Day
Abo Bob
  • Replies 717
Running a dyno comp correctly means this isn't even close to true.
And what would a Journo know :D ....elaborate on your random comment please...some substance to your slur would be nice...we have walked away with silverware in every dyno comp we have entered...its not because we dont know how to win em!!
Edited by DiRTgarage
Yeah, not long now.
That top secret car sounds great and is full of KW but realllllllllllyyyyyyyyyyyy LAGY!
I will be there around 8-8:15, c ya all there.
PS. Hope there is a prize for a dirty car as mine would win!
Yeah, not long now.
RB26 are laggy. Oh sorry shouldn't say that here.
Top Secret GTR is not as laggy now Ben tuned it up much better and makes 449 rwkw on 100 octane pump gas and will let it roar tomorrow.
Stage is set for a big show. The slot car is on the dyno after tickling it this afternoon and ready for first run to demo for those there first in the morning.
Hey John,
RB26 are laggy! - BAN FOR THAT! :P
Not as laggy now hey? thats great :D , Maybe you should take a couple of us for a quick cruze in it.
I will be there early, prob follow Shane.
What's so interesting about watching a video of a car not going anywhere and just spinning the rear wheels?
Its not even generating smoke from those rear wheels, so its even more boring than a burnout.
Banned!! :P :P
What usually happens is that most people come at around the same time so that you will get on the dyno at the same eventual time whether you arrive at 1pm or 3pm probably.
Give me a call 0421 301 061 before coming down if you like and I'll give you a quick rundown of whats happening.
Remember it's 9am til 4pm.
And what would a Journo know :P ....elaborate on your random comment please...some substance to your slur would be nice...we have walked away with silverware in every dyno comp we have entered...its not because we dont know how to win em!!
Hahaha..... You forgot "SCUM!"
Don't forget the little people who've helped you along your way to winning those trophy's, pusseh boy!
Adrian
Guest
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
    • Can I suggest a 15W50 oil is too heavy. Its a brand new engine - you should be able to run something like a 10W30. Shove some steel wool into your catch can  - more technically "oil/air separator" - so that the oil vapour has something to condense on.
    • Nice write up solder thank you.  that problem had fallen into another days fun. I wanted to get this cold side in and turned over so it was wired up the same to get a start. no luck I got a couple of cough’s before the battery died unfortunately. we have some wether on the way and I’m back to work, I will order your plugs and re wire them in the near future. 🤙
    • It was simpler than that. Few things going on. One is that I hate plastic clutch alignment tools. Anybody who reads this in the future and is considering one, don't. Even for 3 USD it's not worth it. Mine left plastic shreds all over the inside of the clutch hub. Now I need a proper steel one and to re-grease the hub splines very carefully without leaving any excess that could go into the friction disk or anywhere else unintended. The second is that I'm bad at reading directions. There is a step in the instruction manual that tells you to put in the 3 M6 bolts BEFORE you attempt to put the clutch onto the flywheel which has been bolted to the crank. You should tighten them slowly and evenly in half turn increments so the springs all compress evenly. Once hand tight back it off until the friction disk can move around between the midplate and the pressure plate. Otherwise the hub won't be able to move properly to line up everything. The last point which is possibly the most important and is not mentioned in the manual or anywhere at all is that the friction disks are actually not symmetrical. There is a very, very subtle asymmetry to the fingers where they mesh with the hub. These fingers need to be pointing towards the midplate. This helps to make sure the friction disks stay engaged with the hub. Otherwise there is a distinct risk they pop up and out of the hub while you assemble, leading to the warped pressure plate I posted initially.
