Sau Nsw Dyno Day
Abo Bob
lol bl mate. Still at least they didn't put up his nos figures...
Yea... But stock turboz.. OMGzz...!@!@ wtf @ 265rwkw it didnt blow up!.. Must have alot of work done to it.
All my mods were cheapo lol
  • Replies 717
yeah he got 265rwkw with nos, between 4000 and 4200 rpm he went from 120rwkw to 235 rwkw!!!! Near vert curve. Crazy.
Nah i didn't talk to ya, but saw u wandering round a few times. I wanna buy the top secret gtr :D
Then put a small projectile in the exhaust and watch it fly away into someone's windscreen as your taking off.
1994 R32 GTR
76,000km
HKS 2530's @ 20psi
260 Poncams
= 301rwkw
I have a feeling the dyno was abit conservative but anyhow it was a great day (even though a touch hot).
Edited by benm
Just had a look at Stan's dyno graph - from the SATANIC. Very surprising to see that UAS backed off the run before it even ended... meant that peak power wasn't even reached??? The dyno graph just went vertically downwards at the end, power curve hadn't even started to dip yet.
Anyone else see this on their graphs or was it just Stan's?
Firstly a big thank you to Adam for putting this together. :/
Also to John and the staff at UAS for running the show.
Very happy with my boat, managed 261.3 rwkw @ 16psi.
Originally had boost set at 19psi,
but I wanted to know how she would go at a friendlier level. :D
Plenty of tough liners there today, some real good numbers.
So who's going to WSID?
1994 R32 GTR
76,000km
HKS 2530's @ 20psi
272 Poncams
= 301rwkw
Mate I had bit of a sticky beak at your GTR when it was waiting in line - all your odometer numbers line up nicely leading me to believe it is a genuine 76,000km? Nice :D
I'm *know* my odometer is a genuine 74,000km :D on the plus side I know for sure the boost restrictor is still in. :/ Comforting.
If I recall his A/F ratios were running a little to lean to push it too much farther.. was a good run.. could have held on a little longer, got a video of it here.. I think the main issue with power was his boost dropping off 1psi..
anyways.. good day.. stuck round for a bit.. than left.. stupid whining gearbox.. shits me to tears now sounds like i'm running a dogbox or something..
Edited by Links
So who won STD turbo GTS-t......
also...who won overall and the reg.?
Guest
    • Nice write up solder thank you.  that problem had fallen into another days fun. I wanted to get this cold side in and turned over so it was wired up the same to get a start. no luck I got a couple of cough’s before the battery died unfortunately. we have some wether on the way and I’m back to work, I will order your plugs and re wire them in the near future. 🤙
    • It was simpler than that. Few things going on. One is that I hate plastic clutch alignment tools. Anybody who reads this in the future and is considering one, don't. Even for 3 USD it's not worth it. Mine left plastic shreds all over the inside of the clutch hub. Now I need a proper steel one and to re-grease the hub splines very carefully without leaving any excess that could go into the friction disk or anywhere else unintended. The second is that I'm bad at reading directions. There is a step in the instruction manual that tells you to put in the 3 M6 bolts BEFORE you attempt to put the clutch onto the flywheel which has been bolted to the crank. You should tighten them slowly and evenly in half turn increments so the springs all compress evenly. Once hand tight back it off until the friction disk can move around between the midplate and the pressure plate. Otherwise the hub won't be able to move properly to line up everything. The last point which is possibly the most important and is not mentioned in the manual or anywhere at all is that the friction disks are actually not symmetrical. There is a very, very subtle asymmetry to the fingers where they mesh with the hub. These fingers need to be pointing towards the midplate. This helps to make sure the friction disks stay engaged with the hub. Otherwise there is a distinct risk they pop up and out of the hub while you assemble, leading to the warped pressure plate I posted initially.
    • ..m'kay.... I see on my phone you're having difficulties interpreting the artfully hand drawn R31 wiring diagrams... you wouldn't credit it, but they're actually more accurate than those colour diagrams in gregory's and the like... ...for your purposes though, the wiring colour legend is on sheet 1.... ....the fuel pump connector is top right on sheet 2.... ...pin1 (black) goes to chassis ground -- pin5 (light green/red trace)... The best way to navigate those drawings, is to open them up in whatever image manipulation/paint program you like, and use the straight line/ruler  tool (with a highlight colour) to trace along the wire lines...not hard, no rocket science involved... Fun facts: The OEM diagrams are drawn to top trim level spec ~ so for example, you're looking at Silo spec wiring, but the base S3 Executive trim is also covered by the same drawing (base models just don't have all the add-on luxury bits) One of the more sublime bits of errata, is this bit... The wire splice between pins7,14 doesn't exist (red) -- the bridge on the cluster PCB between the same pins (green) does exist...but it's not 'there' physically...it's actually more towards the center of the PCB, exactly at the spot where they tend to crack...and if it does, only half the dash lights work... can drive you nuts chasing it ; don't ; just solder in the missing splice... These are 'intentional' soldered and taped splices inside the loom(s) ~ there's also unintentional splices like this, due to manufacturing process when a spool of one particular coloured wire runs out, and they splice in/on a new spool. Those splices above are in the loom, LHS, underneath the front guard panel (remove to get at loom)... if water's gotten into the looms, you can expect corrosion at these splices ... keep this stuff in mind, if in the future you get any weird electrical faults... 👍
    • that looks identical to the WGNC34 Stagea one I was poking around the other day. Is the other end of that not the ECU plug? If so checking continuity at both ends will tell you which ECU wire it is.  I can start by telling you ECU pin 31 is the top of the large pins on the right in your second pic
