  • Replies 717
It only took that long as I asked Ben from UAS to ramp it slowly to 4400rpm then bury it :/ Not a great idea ramping from low rpm with nitrous on a dyno under load. Rods don't like it. lol
I was happy with the 190kW no gas - I hope anyone who watched the curve or saw the power vs. manifold pressure graph took note of the values. If there are any old pricks with something to say purely for the sake of saying something still talking i'd be surprised.
Thanks to Adam, Turbosmart and UAS for a great day.
Adrian
whatever u did it was awesome to watch man. Did u end up taking out stock turb winner?
Nothing like the Nissan hardware doing the sh1t....well done 2rismo.
If only Stace had her Nissan with bolt ons there to blow the "top secret" apart...T88-34GK...lol...put that turbo back on the truck it belongs on!!
It only took that long as I asked Ben from UAS to ramp it slowly to 4400rpm then bury it :D Not a great idea ramping from low rpm with nitrous on a dyno under load. Rods don't like it. lol
Adrian
Congrats to the win! :no:
lol no hard feelings now d00dz??
:no:
Naw.. But Adrian musta spent heaps on the car.. powerfc, boost controller? etc...
Mine didnt even have a powerfc!!!! or boost controller.
Ah well... Im surpised at what I got anyways.. It was like "OMG WTF?"
Ya.. Think first run was 170 something which was expected. Then they did another and it was like 178? then they rested the pc and did another and it got 180 something... then they did another and it got final value of 180.2.
So they did like 4 runs of my car yay :no:
Weird dyno... Gonna go back to another dyno next week maybe, just to see the values, coz initially I had 158 without the fmic, turbo back, hiflow.
Its gonna be interesting..
OH GREAT WORK TO ADAM AND THE SAU TEAM FOR DOING THIS. Not to mention UAS dudes.!
Adam any chance of posting all the results in say the Members forum?
It was a FUN FUN DAY,
I was suprised at my result.
I am thinking the dyno reading rather high???
Bought my R33 Stock 4 months ago.
these are the mods i done:
- split dump + 3.5 Hks cat back
- r34 IC
- K&N POd + heat shield
- 35 bucks boost controoler
i was expecting 170-180 kw,
but i got 197.4 KW @ 10 PSI,
something isnt right?
Edited by RBFIRE
Im a bit sceptical of the power figures......
my run was all over the place and yeah my reading was 40kw lower than my last tune.
183kw....stock turbo but pretty much everything else.
power fc
EBC
front mount
exhuast from turbo back etc.....all base mods basically.
first run was 256kw and I was like...nah it cant make that much power.....so I told them and they said the air temp sensor for the dyno had gone haywire, so they replaced it and had another run...183 first run and second got 203 which sounds more like it....but for some reason I got the print out of the 183kw????
Anyways it was a great day despite that and id like the thank adam, steve and charlie and anyone else who helped to make the day possible !!
adam bring bob along next time!! :no:
Edited by shonen
Guest
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
