Seems to me that the air-temp sensore may have been on the way out earlier in the day. Not taking anything away from anyone in particular but does anyone think that a stock 25 can make 175kW on 9psi and stock ECU? Or that a stock RB20 can make 185kW on 10psi with a stock ECU?
Confusing but don't know that it would've affected results or not...
Adrian
Maybe the dyno was still in shock after the UAS Zed as i went on the dyno right after it. :D
I think no matter what going to a different dyno on the same day will give you different results.
I have had my previous cars on a few dyno's and have had a diff from 5-25kw.
Maybe we should just average them out!
  • Replies 717
hey it was a great day
i just wanna know if 2riszmo payed dubble for his 4 runs ??? didnt seem really fare if he didnt everyone gets 2 an he gets 4 ???
Nice. Speak to Ben who was running the dyno about that one. Either way my first run was enough. The nitrous runs were all for show :P
Adrian
Yeah well done to the organisers!
I had an awesome day as after my run, one of the guys said I should be getting more than 185kw, considering I've got an aftermarket turbo. And after 6 months of owning my car, I've finally realised that I have an Apexi AX53B70 P25 (380HP) Turbo in my car! I thought it was stock all this time, and never looked hard enough to really check (its completely hidden from view).
Even the last owner told me it was a stock turbo!! lol :D
Time to crank the boost!
FFS!!! What are you waiting for man.An invitation.. :P
The nos runs were the most entertaining i saw all day, a close second was the zed at the end of the day..
I strongly agree with some others that were there all day that there was definetly some fishy figures coming out, in particular the high ones (maybe not high enough) and the low ones (too high!)
Either way i dont care it was a awesome day to watch and chat with the other guys.
i was a happy with 193rwkw.. stock turbo r33 gtst. wish i could have stuck around to see the end results on who won that category.
Adrian (2rismo) ran away with it, with 190rwkw.
Very nice prize eh ?
El Bee
ps I would like Adrian to define "old pricks" from a previous post. I don't think that it is nice to be ageist in this forum, as I have not seen an age limit on membership.
Guest
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
