Hey I've been having a few issues recently with the way my car is running. for some reason it feels like its running with a cylinder short as I'm losing power and the car isn't idling smoothly.
so I thought I'd troubleshoot it by logically changing the sparkies and realised the previous owner had put in cheapo $5 ones. after a good 2 hours of replacing the sparkies the car ran fine and idled better.
about 15 minutes into driving on the freeway it started running lumpy again the same as before I put the new sparkies in.
I'm guessing it could be fuel issues as I filled up at a Mobil 7 Eleven outlet the other day so I'm guessing dodgy fuel. but it only happens at certain times and is more frequent every time I drive it.
just wondering if anybody has any ideas of suggestions. I'm guessing it would be a simple case of a clogged injector or stuffed coil pack.
I'd prefer a simple way out if given the chance.
https://www.sau.com.au/forums/topic/103026-i-think-shes-sick/
Remove the centre Nissan branded spark plug cover panel. Run car without this. Pull off one plug to the coils one at a time. That will tell you the cylinder that is down - if that is the case. Then check the spark plug to see if the plug looks different to the others. Swap coil packs and see if the fault stays at the same cylinder. Check the loom etc to see that hasnt deteriorated.
Edited by benl1981
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
