Had my r32 gtst tuned by Sam aka Dr Drift yesterday and i cannot reccomend him enough. He really gets nothing less than the best from your car. I think we were on the dyno for close to 3 hours and he charged me for a bit less, so i was really happy. Not like other places that want to sting you for the last 5 cents they can.
Anwyays im sure most of you know his work is 10/10, here are the results.
This was achieved on stock injectors so it shoudl also silence a few critics.
When you look at the dyno graph you can see what i went in with and what i left with. What you cant see is the afr's that were all over the place with the chip i drove in with and how perfect they are with the chip i left with.
Made my day :)
https://www.sau.com.au/forums/topic/103040-dyno-results/
looks good. Sam knows what he's doing :)
did you get that done up in brisbane?
what turbo have you got? Rb20 i presume?
Cheers.
Sorry, relevant mods to the RB20 are hks 2530, nismo adj reg, bosch 044 intank. Top quality intake and exaust systems help too. I think the stockers limit is around 160-170 but i could be wrong.
Anyone who gets the chance i highly recommend, i would truly be disappointed if i couldnt have him tune it again in the future. Possibly for some tomei poncams (stuff adj cam gears) and nismo 550 or 600cc injectors.
I also have fuel economy now !!!!
EDIT: yes this was done in brisbane, gold coast actually and was @ 17 psi
Edited by 26GTS
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1893689
thats good power for a 2530!
and yeah, getting good fuel economy was one of the highlights :)
do you have a z32 afm too?
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1893705
what are the air/fuel ratios like now, around 12:1? put up the graph if you can.
Yeah the air fuel ratios where as sweet as could be, around 12:1
I dont have any graphs with afrs on them, i was watching them on the screen though as he did run after run, tweak after tweak :)
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1893865
How is your fuel economy now
how many litres per 100 km?
cheers
I dont drive it sedately enough to tell you sorry, plus i only got it done yesterday. If i could manage to drive it without flogging it then that might help. Its also my toy car so i only drive it a 5 or so times a week.
All i can say is its much better between 25 and 50% better at a reasonable guess.
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1893999
Do you know if he emulates or does he burn chips ervery time he makes a change?
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1894395
Not really (not that im a critic)
But you've obviously bumped the rail pressure
nismo adj reg
So its kinda hard to tell :P
If you hadnt bump'd the pressure then i'd pay a silence of the galleries :(
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1894570
Oh... and Sam was getting Emulation last tiem i spoke to him (couple months)
So i'd say one burn @ the end and she's away
He emulates them for sure, very tidy equipment he has been developing for years now.
And yeah Nismoid the pressure is bumped up, it was really only significant because sam had never tuned that from stock injectors.I plan to get the injectors and cams before he is back next. That should enable me to find the limit of the 2350.
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1895667
i've got a similar setup (2530/RB20) and i'm not making as much power but mine seems to come on boost full boost (18psi) about 400-500rpm earlier from what i can see on your graph.
Damn, that sucks, i really dont find it laggy at all though very compareable to the stocker. I have a Profec b spec 2 that opens the holds the wastegate shut untill it reaches .75 bar.
I dont think you can tell how laggy something really is on the dyno
My 2 cents :(
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1896846
You'll find that most operators don't really start loading up the car below 3k so it doesn't give your turbo the opportunity to start building boost as it would on the street. On the dyno i hit 20psi by 4k, on the street it's more like 3200.
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1897218
but think about what u just said, it that really giving u a good tune??
your gonna be tuning it for lower load points on the dyno then it hits the road and its using higher load point which wasnt tuned as well.
u got a dyno to simulate the road conditions and u dont use it to the full potential, i think thats abit silly.
thats my 2 cents, no disrespect to anyone.
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1897401
Glad to hear your happy with the tune, I was :)
yogi - Most of the low to midrange has been re-done, some runs were loaded up down low, Mick's car has excellent transition from the 14.7 AFM when running on the factory O2 down to 12.0 as the car's generating boost.
https://www.sau.com.au/forums/topic/103040-dyno-results/#findComment-1900202
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
