I currently have a 1990 hillux surf turbo diesel which I imported about 6 months ago to which I have done a few mods which is my daily driver but now want to sell and get either a Soarer V8 or Celsior V8 coz driving a big diesel 4x4 everyday is a pain in the ass, especially is city traffic. The R33 spents most of its time in the garage when not being driven on the track.
This saves me alot of $$ on petrol and hassels from cops as I work in the city about 40km from home.
There are alot of soarers for sale but only a few celsior, which cant be imported now either under the 15 year old rule but they both have the same 4.0 engine.
Who's owned one or had good/bad experiences with them?
Yes I have already driven both before but am stuck between the 2.
Yes I need people on the internets views before I buy one :):)
https://www.sau.com.au/forums/topic/103061-soarer-or-celsior/
  • Replies 41
type C F has massage rear seats, standard leather, air purifier the whole lot.
you're not really pimpin unless you in a C F.
i was lookin at getting into a celsior not long ago, there is a whole lot to look out for with these cars. you can quite easily end up spending a GTR-load of money getting them up to scratch, not a cheap car to run.
check out some of the info from the toymods forum -
http://forums.toymods.org.au/index.php?t=m...94a6ebc98d80888
helped me decide i didn't need one :D
I'd get a soarer Denham... unless you want a 4 door. Just because there so many of them around these days, parts would be a bit easier to get.
Most of the JZA80 Supra suspension components and the like bolts straight into the Soarers, which might mean its cheaper prospect - if there is anything like that needs replacing.
If you want a four door, get a Celsior. If you want a two door, get the Snoarer.
They're not exactly similar cars.
A friend of mine had a Celsior for a while. The V8 sounded nice with its catback, and was smooth. It was a full luxo inside, with a rear seat you could use. A pretty nice car - shame you weren't looking for one a month or so ago.
Yep looks like I am going with the celsior.
Checking out my mates I might be swapping with tomorrow again.
Heres mine. black one is for sale atm - put it up in FS section, but for some reason i think someone deleted it.
There are many things to look out for on celsiors. air suspension is not really a problem...its more the shockers and ball joints.
BTW - CF is more luxury but if you have a C model, you can easily add rear massagers - they are a seperate unit that is added in the back of the rear seat and you can get em from japan easily.
How much u selling the black one for?
I think i will just put some 19's or 20's on the 1 i get and not the bodykit so I wont have to worry about going uo driveway/carparks and hitting the kit I have to with the R33.
How are they as a daily driver? Are they good on fuel?
get an aftermarket suspension height controller and your driveway problem is solved :(
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
