to answer your questions:
they are only bad on fuel if you drive it like an idiot. they are 4.0L V8 so they arent too bad....very easy to speed in though. not the quickest of the line compared to a 5L V8 holden, but get going once they are rolling. they are alittle tough on petrol if youve had them a bit modified. but what do you expect its a V8.
engine wise they arent too tough to work on, but you have to take alot off to get to the spark plugs and a shitload off to get to the timing belt and once there you might as well replace the water pump.
havent had any problems with the air on both on them, but theres plenty to look out for. mostly the valves on each strut will be old and worn. most of them are lobsided as well (left sticks down more then the right side other vice versa), but this can be changed manually and on a controller if you have the function - most newer ones do.....the ride depends on ball joints (which are mainly f***ked) and how low the car is as the dampners are chaned automatically on a lower ride.
  • Replies 41
if you have a celsior and you want it pimp....you have to get a huge bodykit with some deep dishes :( dont get 19/20s from australia if they arent deep dishes, i think they look crap on em.
the bodykit is no problem! thats why you have air suspension! a controller is EASY to get if you dont have one and theres plenty around. but depends what you want and what look you are after.
i drive my blue 1 as a daily since i moved house and only hav 1 carport. they are perfect as a daily driver....does chew up some petrol but hey thats the price you pay for having a car like this. it really is ultimate luxury if you find a good one. even better with some mods.
i just got the black one ADR complied....it was going for $9999 uncomplied, but will end up around the 12K after i get it passed through regency. its on carsales if you want more pics.
With a suspension controller can you drop the car down on the chassis rails when parked?
depends if you have aftermarket air suspension or not...and depends what type of controller you have. also depends where the manual hieght of each strut is normally as to how extreme low it will go.
Smellsiors are cool. Everyone at work except me owns one. From grandpa style to VIP style.
Soarers though are the shit, its like a monaro, only better.
If I was given the choice between a C Type F package Smellsior and a V8 Soarer I'd be going the smellsior, much more mature, more features and buttons than you can poke a stick at, and much better looking I reckon... it just has a presence that follows it around with just the right kit, paint and rims.
Denham, we've still got a few 15 year old smellsiors waiting to be sold sitting in japan (approvals n stuff have already been gotten) pm me and I'll give you some links.
U already have a PM from me about ghosting that hd for the ps2!!
Send me some links to the celsiors u have for sale
well i have a soarer. and i can tell you either the celsior or the soarer will not be a very cheap car to drive. they loooove the fuel. i mean it is a heavy car with a V8 after all. The soarer is great though. i have an active model which means instead of the dodgy airbags i have hydraulic suspension. it's a good car for the money. every option under the sun (including reverse camera which i love). looks good and is very comfortable, but quite slow, and fuel hungry.
But doesent the celsior have a damn big fuel tank???
Exactly.
My mate's ex-Pursuit VT SS was getting a similar range out of a tank (maybe a touch more). Mind you, it had a secondary fuel tank which brought total capacity up to 100L. I could fill up, pay, and check my tyre pressures by the time he filled up his tank.
R108's mate, look like the 17's on my Soarer.
The V8 is plenty good though in these and I've done 8 hours on a tank through NSW on the Newell Hwy, but using the standard wheel/tyre size. 10km/l average at 107kmh on the cruise control that is now modded for unlimited up to 180kmh. It drops in economy a bit on wider ones (235F/255R) to around 8km/l on the EMV screen and a bit over 6km/l around town pushing it. Tossup which I prefer around town, R33 auto or Soarer V8. Both use about the same fuel but it's still heaps less than the GTR (only cos I like to punt it a bit).
Celsior was the only choice for a swap though, why would you chase a Soarer? We must drag sometime :unsure:
Celsior was the only choice for a swap though, why would you chase a Soarer? We must drag sometime :)
Thats one thing i forgot about with putting on 20's is fuel economy!! :)
Some pics of my celsior after I gave it a clean today.
The pimping will be done soon. Ordered an air suspension controller from japan so I can dump it more than currently, and still checking out which 19 inch rims I am going to get.
DVD/MP3 and flip out screen with focal and mtx stereo also to go in in the new month.
U can even see the good old R33 in the background which doesent get driven much these days :P
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
