Ring Anthony at Turbotechnics. Tell him the guy with the burgandy skyline sent you and he will do you a good deal. He has done these before. He is real good with RB's
Call Anthony on 49565466
TWO.06L off here is the best builder of an RB around here. No questions. If he will do it for you, you'll have to pm him and ask nicely I'd say. This is if you want it done very well, be prepared to pay for the quality ofcourse. Wouldn't bother if you are looking for a budget solution.
Thanks psybic, yes we do all our own engines...and customer engines too. Although our head work is outsourced as the guy we use is simply too good. We are not budget builders, but in saying that i rarely see quality offered cheaply.
Yep I have been discussing this with Paul already :D
i dont think i will take it to Syd, just a pain to get it down there when I cant really drive my car. Also I have heard mixed opinions about Hunter Thomas. One of my mates reckons the's the best and then i have a couple others who reckon the's a rip off! Well i got myself a few months to decide because of lack of funds :)
Seeing you created two of these thread's phil, i see my other comment has gone astray!
But i also would get ye ol' locals at DiRTgarage to make your engine healthy again. As stated by paul, you cant comprimise on quality when it comes to a rebuild. And im sure he'll do a great job for ya.
(Btw Paul, finally got all those darn defects cleared too :D !)
Haha, i asked that question a few months ago too!
I got mine from:
http://www.pixelcars.com/
However, when i tried to access the site then - it wouldn't load up.
Apparently the owner got fed up with paying for his forum to be hosted or something....
So i dunno where you can get one from now!! :P
Maybe Paul or Stace will give you some tips :P
Hope the rebuild plans are in full swing for ya!
-Dave.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
