3" turbo back exhaust
walbro pump, gtr injectors, malpassi 2-1 reg
600-300-76 hybrid cooler
T3/T4 turbo (T04S comp with std hiflo rear, not ball bearing)
wolf 3d ecu + ebc
splitfire coils
k&n pod
done 190kw on 22psi
new turbo setup going on at the moment, ordered a GT3071R.
Edited by grim32
R32 with
* Stock Auto
* Nismo FPR
* Apexi S-AFC
* K&N panel filter
* Highflow RB25 turbo (unknown brand)
* 16psi boost
* 3" dump, 3" highflow cat, 3" catback with magnaflow muffler
* Hybrid style cheapie 400x350x60 cooler
Fuel: BP Ultimate.
Dyno Temp: 34deg
1/4 mile: 14.651 @ 100mph
Reads low on the chart i guess.. As you can see, non-shootout mode, no temp correction, etc, and 30+ deg day which explains a bit.
92 R32 GTS-T
- Internally std RB20DET
- Trust TD06-20G 8cm^2
- Greddy Exhaust Manifold
- Greddy Type R Wategate
- HKS Type S Intercooler
- HKS Hyper Exhaust
- HKS cam gears
- HKS Air Filter
- Apexi Power FC
- Bosch 040 fuel pump
- Std GTR injectors
- Z32 AFM
- Splitfire coils
- BP Pump Fuel
Non Shootout Dyno, whatever that ends up equating to. Dynod to 7,400rev limit, these days using an 8,300rpm rev limt :D
...also, its interesting to see that the RB25 turbo is only making the same power as the TD06 at 80km/h, but from their on the TD06 walks away making more power
  • Sad 1
1993 Gtst Type M Coupe manual
Relevant mods for power:
Blitz LM spec air filter
Blitz Bov
Hks 2530
Nismo adj reg (pressure raised from standard)
Bosch 044 intank
Dr Drift remapped ecu
Bosch Z32 afm
Stock injectors
Trust R-spl i/c
Trust PE II catback
Catco 4inch cat
Batmbl blended dump/front pipe
212.8rwkw @ 17psi
The lower run is from a toshi remap....
Edited by 2630GTS
1987 HR31 GTSR
Stock TO3/TO4 turbo @ 22psi.
Stock front mount cooler. - ceramic coated piping
Stock nismo tubular exhaust manifold. - Black ceramic coated
K&N pod
Inlet butterflies removed
3 inch exhaust with Magic CAT
Remote mounted AU falcon coil pack
GTR fuel pump
500cc XR6 turbo injectors
Autronic SMC
optimax
Edited by FATGTS-R
  • Like 1
* Internally standard RB20DET
* 3" turbo back exhaust, supercat cannon with 5" tip
* Hybrid style fmic
* Apexi power fc
* Apexi AVC-R
* Apexi pod
* Sard 550cc injectors
* Turbosmart plumb back BOV
* Rebuilt turbo by Garrett, 400 - 450hp
* Bosch 019 fuel pump
* 20 psi
This tune was done on Monday, and as you all know it was 36 degree's out here in Penrith, so that was a bummer. Also im maxing out the 019 fuel pump so the tune had to be restricted because it was unsafe as it was leaning out too much in the top end. Ill be putting in an 044 pump when i can afford it and i will post up the sheet once its tuned.
  • Like 1
RB24DET
Tomei pistons
GTR rods/crank
Tomei HG
Standard head and cams
Modded GTR Plenum
Greddy high mount manifold
Trust Ext Gate
3" exhaust + standard cat
KKK-K27 turbo
Moddified GTR FMIC
220rwkw@12PSI
Laggiest setup i've driven! lots of things to work on though.
89 shtr
standard rb20
Apexi AX53B70 P-25 (380hp)
gtr injectors and pump
z32 afm
ap engineering power fc
600*300*100
3" dump, no cat and 90mm cat back
turbotech boost controller
standard bov
more fixing and boost needed then hopefully 250rwkw (335rwhp) or more
Edited by Cerbera
1995 240sx(s14) with 1993 r32 rb20det swapped in
pod filter
buddy club spec 2 exhaust
internally stock rb20
tomei cams (260/8.5)
greddy gears (not degreed so set at 0)
rc 550cc injectors
z32 maf
ecu retune to suit maf and injectors
RIPS intake manifold
hks cast iron exhaust manifold w/ std gate
greddy e-01 boost controler
garrett gt30r with .63/ar turbine housing
24"x6.5"x3.5" fmic core (spearco bar and plate)
tomei r32 gtr fuel pump (cheap from a mates part out)
run was done at 17psi, and we stopped due to the fact that it was too lean on the bottom end.
eventualy corrected the lean spool but motor died from unknown reasons a few months later (suspect high egts)
92 R32 GTS-T
- Internally std RB20DET (113 000kms)
- HKS 2530
- Std Exhaust Manifold
- Std Blow Off
- ARC Front Mount Intercooler Kit
- 3" Dump & 3" Catco & 3 1/2" Cat back
- JUN cam gears
- Std Air Box
- Apexi Power FC
- Blitz Spec S Boost Controller
- R33 GTR fuel pump
- Std GTR injectors
- Z32 AFM
- Splitfire coils
- Optimax Pump Fuel
93 R32 GTS-t
using completely STOCK (un-chipped) computer
stock auto transmission
stock injectors
Cat back 3" zorst
front mount intercooler
os gieken adj cam gear (exh only)
Arias Forged pistons 20thou ovesize
ported and polished heads
1mm oversize valves
match ported manifolds
ported exhaust manifold
high flowed VG30 Turbo
Sard Adj Fuel Reg
Fully balanced and machined bottom end
AVCR boost ctrl
k&n flat panel filter
standard injectors
R32 GTR Fuel pump
Std Blow off valve
Caltex Vortex 98
208.1 RWKW at 1.4 BAR
Edited by DRFT32
internally stock RB20, 171,000kms
HKS 2510 turbo, 1.3bar
300x600x50mm cooler
PowerFC with boost control kit
GTR injectors
044 fuel pump
3.5" dump/exhaust
stock exhaust manifold
Z32 AFM
best dyno was 208rwkw
currently running about 190rwkw due to conservative tune (random knock on PFC hand controller)
Attached is a few differant dynos, each with differant boost/tune
300x600x50mm cooler
GTR injectors
044 fuel pump
3.5" dump/exhaust
Z32 AFM
I had mine dynoed again on Dr Drifts brand new dyno on friday night....
208.8rwkw at 16.5psi.
However, the stock actuator on the R34 GTT highflow turbo is only rated at 7pounds (i think) so it can't hold boost properly and it spikes badly to almost 19psi. On cold days (low ambient temps) it spikes even worse so i'm looking at changing to a HKS GTRS pretty soon. or as soon as funds allow.
Mods are the usual:
Z32 airflow meter
Nismo 555cc injectors
Full 3" exhaust
K&N pod
Dr Drift remapped stock ecu
HKS type S intercooler
R34 GTT highflow
Bosch 040 fuel pump
Dr Drift boost controller
ALL those people who have dynoed their rb on Dr Drifts new dyno should put their runs up too - i know there already have been heaps despite the dyno only being 1 week old! :blink:
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
