got my 89' automatic r32 rb20det skyline dyno'd today
K&N pod filter(no heat shield)
r34 smic(1 of the pipes keeps popping off)
3" combined dump & front pipe and 3" hi flow cat from BATMBL
3 1/2" JASMA cat back from Japan.
$22 manual boost controller
r33 turbo 14psi(drops off to 11psi)
apexi safc tuned by HITMAN
was done in 4th gear
143.9rwkw
my first ever dyno with the cat back and pod filter i got 127rwkw(was done in 3rd gear)at Silverwater Automotive Services
both dyno sheets r displayed using my camera fone
the before(red line) on the HITMAN readout says 126rwkw
thats with everything minus the boost controller and safc.
Edited by RSTME
VH Commodore, R32 RB20DET
Std engine and turbo,
quiet 3" exhaust,
400x300 K&J cooler,
EMS computer
163rwkw @12 psi on JPC dyno
12.90 @ 111mph with stiff circuit spec suspension, old Advan tyres.
Fitted HKS T300 turbo and Tial 38mm gate, made huge difference. estimated 200? rwkw @ 18 psi. Will dyno soon.....
1993 RB20DET stock internals
3 Inch Turbo Back Exhaust
GTR Front mount
Stock Turbo
POD
Turbosmart Bleed valve
98 octane fuel
Power FC Tuned by Unigroup
166Rwkw 1 bar boost
Edited by Dave69001
R32 1993 GTS-4 Turbo
Standard RB20DET
Standard turbo
Standard computer
walbro 500hp fuel pump
3" turbo back
K + N Filter
stock boost when dyno'd and got 145rwkw on a 42 degree day
now i have installed front mount and upped the boost to 1 bar
I have a boost controller and I used it at three different levels
so at 14 PSI:
wheel crank
hp 265 335 @6250
tq 230 285 @5000-6000 Smile
__________________________
at 14.5 PSI:
wheel crank
hp 270 340 @6500
tq 240 298 @5000-5750
at 15 PSI:
wheel crank
hp 280 355 @6500 that's 208 RWkW
tq 260 315 @4750-5500 352 RWNm
Old ass blitz SBC boost controller
HKS GT2535 turbo
(N1?) GTR FMIC
Tomei Built RB20 2.2L with cams and all
GTR Injectors and Fuel Pump
3" catless RS*R exhaust
Z32 MAF
94 Canadian Octane gas
the tune is quite rich
You guys think it's the turbo/cams/injectors that are running out??
this turbo is rated 350HP which I'm at :S
Edited by klys
1986 200ZR NICS RB20DET
3" Turbo Back Zorst
Pod
R33 Turbo
SAFC2
Supra FMIC, 2" piping
Stock Fuel System (injectors, pump etc)
Turbotech Bleed Valve, set to 10PSI
144.1RWHP (108KW) sad, I know :no:
AFM hits 100% utilisation @ 5500RPM and everything goes to shit after that.
Edited by 200zRRR
Yo, my car is an A31 Cefiro with an R32 RB20det
Mods:
HKS Pod
3 inch exhaust
600x300x100 cooler
Custom inlet plenum (copy of jun surge tank)
Garret GT25 400hp turbo (0.64/0.70)
tuned length stainless high mount manifold
tial 38mm gate.
GTR Fuel pump
550cc S5 injectors
Sard Reg @ 40psi
RB20 AFM mounted in 4 inch intake pipe
Power FC
Just got back from tuner 2nite & the results were: 258kw@ 18psi (dynapack chassis dyno) supposedly it works out to 406hp @ the flywheel.
Lastest tune and mods
1992 R32 gtst
rb20det stock bottom end (65000klms)
hks cast exhaust manifold
hks 35mm external wastegate
hks adjustable cam gears
hks 264 cams 9mm lift
600x300x76 hybrid intercooler
malpassi fuel reg
sard 550cc injectors
ported and polished head
catco high flow cat
custom 3' dump
hks 3.5 exhaust
garrett GT3040R turbo
Haltech ecu e11v2
Made 281.8 rwkw @22psi
R32 gtr fuel pump
cheers Peter
Edited by legend01
hi, unfortunaletly i don't have an electronic copy of my dyno to post up, but here are my mods and result.
1990 R32
Standard rb20 internals
rb25 series one turbo on stock manifold (using rb20 wastegate actuator)
quiet 3 inch zaust, custom dumppipe
k&n pod in cold air box
stock AFM
Retuned ECU
14.1psi - via an E-Boost
300x600x76 bar and plate (no brand) intercooler
custom intake manifold (front facing throttlebody)
460cc rx7 injectors (non turbo)
proSport fuel regulator
standard recirc BOV
192.6 Kw's at rear wheels on torque performance dyno (i think temperature was 23degrees.)
i just picked up my line, so thought i'd put up the details (not much to brag about though) ;-)
1993 R32 GTS-T (5 spd)
RB20DET (wrecker engine - standard internals)
stock RB20DET turbocharger & dump pipe (stock boost)
stock exhaust and inlet manifolds
stock AFM
stock injectors, etc
stock intercooler & BOV
3.5" aftermarket cat-back exhaust
K&N pod filter
Apexi PFC - conservative tune
132 rwkw @ stock boost
p.s. i have bits sitting at home waiting to go on to get this thing boogying
