1989 r32 gtst auto
standard everything apart from:
2.5"slipt dump pipe
full 3" exhaust
cheap as pod filter (no cold airbox or heatsheild)
600x300x76 FMIC with 2.5" piping
stock boost
139.7rwkw
Edited by nizmo_freek
1989 R31 Skyline
Stock R32 RB20det
202rwkw at 16psi
HKS GT2535 turbo
3inch exhaust
Apexi PFC
Apexi pod
GTR injectors
Nismo fpr
Bosch 040
GTR cooler
Profec B
Edited by R31 POWER
Power--------> 299.96 rwhp @ 16 psi
Car ----------> R32 GTS-t (92 model)
Motor--------> Rb20DET (stock internals)
Mods.
Blitz LM Front mount intercooler
Apexi pod filter
ITS Turbo bush bearing core (unknown spec but lag monster.)
RX-7 550cc red top injectors
Full 3" turbo back exuast with high flow cat (xforce)
Sard oil catch can
Z32 AFM
Stock ecu with personal tune/remap.
Bosch 040 intank pump.
Boost starts at 3k and doesnt hit 14 psi till 6k.
Gtes the kick in the back at 4.5k.
A/f ratios were 11.8 after 4.5k.
I have run it at 20psi without fueling(a/f around 11.4) or detonation probs on and off for the last 12 months but have not had it on the dyno for that amount off boost yet so I have no idea on power but it scares the hell out of me. HKS GTRS turbo swap to come in the near futuer for more drivability.
1989 R32 gtst rb20
manual with heavy duty clutch
stock internals
gtr fuel pump,stock inj
stock turbo
3' turbo back exhurst no cat
hybrid front mount
manual boost controler set to 15 pound
made 160rwkw
13.7 quater mile on street tyres
1990 R32 GTST
RB20DET stock internals
HKS GT2510 @ 1.3bar
GTR injectors
Bosch 040
standard afm
3inch exhaust no cat
Trust fmic
Tomei Eprom
SAFC2
288 HP @ wheels or 215rwkw
The A/F ratios are a bit suss due to the tomei eprom i think. im hoping to get rid of the SAFC and get a custom
tuned eprom to get the A/F ratio a little better and squeeze a little more out of it.
i will update this post after fitting a more a/f friendly eprom with a full boost reading.. for u jazza ;)
Edited by BSK
HR31 Coupe
197.7 rwkw @ 13psi on the UAS SAU Dyno day, stinking hot and humid day
silver top engine swap, R32 gearbox, twin T28 turbos, custom 3" turbo/s back exhaust, 3" high-flow cat, 700hp hi flow in-tank fuel pump, 444cc/min injectors, microtech LT8 (grrr) ECU with handset, turbosmart T piece boost controller (needs to go), custom ceramic coated intake piping (it's black, and coated, so meh), big ass FMIC, 700hp rated clutch, twin pod filters, standard bottom and top end, malpassi fuel reg, fully re-done cooling system (radiator, thermostat etc, all after the dyno run, not like it'd matter anyway) and i can't remember the rest. Might get around to scanning the dyno chart some day
91 R32 GTST
Standard RB20DET
Pod filter
3" turbo back exhaust
Adjustable FPR
TD05 small 16g (from mitsu Evo II)
Tial 38mm External wastegate
600*300*75 FMIC
Standard ECU
Standard Fuel Pump
194.5 rwkw @5900 running very lean on 13.5psi
Edited by Adidan
VL Calais RB20DET
Lowmount GT2530
GTR Injectors
Wolf3D V4
Eboost
HKS FMIC
Standard inlet plenum
3" cat back exhaust, 2 3/4 past muffler
180rwkw @ 18psi on 39 degree day in Townsville with conservative tune
Had pulled 199.6rwkw at Rycol but don't have the slip.
Planning on increasing boost to 21psi for a run in July...
Stock RB20DET
Only mods are:
3in zorst, no mufflers...
Pod..
Front Mount..
044 fuel pump mounted intank..
EDIT* running 10 pound of boost.. no controller...
no tune..
Pulled 216.5rwhp with a bit of ping ping
Not too far down the track will be fitting IHI RC6 turbo, with cast manifold and ext gate, GTR injectors and a Lumpy Rom... probably Z meter as well.. looking for at least 260rwhp
Oh and pic of dyno readout:
Edited by Josh
92 R32 Gts-t - Manual
Internally standard RB20DET
* 4" HKS Super Dragger exhaust with 5" tip
* fmic
* k & n pod
* Blitz BOV
* Bosch fuel pump
* Nissan Stagea Turbo
I ran a 13.9 sec 1/4 mile.
243.8HP
She was dynoed at 189HP before the fmic and turbo conversion.
Edited by RB_turbo_bitch
91 GTS-t
- Stock RB20 and computer.
- 450 HP high flowed GCG built turbo.
- FMIC.
- 2 1/2'' cat back exhaust.
- Rx7 fuel pump.
- EBC.
- 11 psi.
Leaning out like a motherf_cker.. (14.3)
Made a massive (jokes) >147.
Will post new results by 07/07, after new goodies are installed....
29.07.06
Ok a bit longer than the 7th, But any hows.
- Microtech lt12
- fuel reg
- New pump
Made 210 on 16 and 227 on 19. (RWKW, for you kiddies playing at home)
PURES LIKE A f**kING KITTEN.
MANY THANKS TO SIMON FROM NT
Edited by 32brother
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
