Stock RB20DET
Only mods are:
3in zorst, no mufflers...
Pod..
Front Mount..
044 fuel pump mounted intank..
EDIT* running 10 pound of boost.. no controller...
no tune..
Pulled 216.5rwhp with a bit of ping ping
Not too far down the track will be fitting IHI RC6 turbo, with cast manifold and ext gate, GTR injectors and a Lumpy Rom... probably Z meter as well.. looking for at least 260rwhp
Oh and pic of dyno readout:
Will get dyno sheet up soon..
Just replacing the turbo with the IHI RHC6 and the external gate the car made 299hp on hyperdrives dyno, Oh yeah - it is also now not running a cat and has a sard fuel pressure reg on it.. its fairly laggy too.. fun to drive tho..
Took a while haha
First pic is the original 299hp (on 20 pound) dyno run
Second pic is of 312hp(232kw on 22 pound) run after it had been rommed, new injectors, airflow metre, cam gears and avcr. the cam gears managed to bring full boost on 1000rpm sooner which is what I was am really happy about, I know it could make more power, but it would really put a strain on the engine, so im rapt with were it is now
90 gts-t
fmic
walbro 450
3inch exhaust turbo back
pod
hybrid controller on 1.2bar 18psi but steadys to 14psi
possibly vg30 turbo???? yet to confirm
done on roller dyno on 18's with 40psi in em
ive got a 1993 r32 gtst running:
Rb25 turbo
apexi air filter
std injectors
3 inch exaust system
gtr fuel pump
hybrid gt spec intercooler kit
hks spark plugs put in for the last run as u can see
apexi AVC-R
Apexi SAFC 2
running 12 psi pulled 186.33rwkw dynoed at BD4'S
RB20 Stock internals
3" turbo back
manual controller set at 14 psi
stock turbo
apexi air filter
fmic
stock injectors
upgraded fuel pump
dr d ecu chip and remap
204hp @ 10psi ...159rwkw @ 10psi.
remuffler removed made 162rwkw @ 10psi.
boosts up to 14psi then just tapers off as it losses boost.
wont hold boost for some reason.
dynoed at phat performance on the 16th this month.
  • 3 weeks later...
just got the dyno done on the beast at race solutions....
170rwkw or 225hp on 11psi :);):dry:
from this beast wich is for sale
RB20DET
R33 turbo
FMIC
GTR fuel pump
pod filter
if interested follow or cut and past the link below
http://www.silviansw.com/forum/posting.php...st&p=213492
Rb20det
rebuilt motor with stock pistons
recoed head with slight port polish
tomei cams
greddy td06-20g 8cm
6boost manifold
tial gate
3inch exaust
gtr injectors
power fc
bosch 040
hks front mount
custom plenum
stock afm
sard fuel reg
probably a few more things on it...pulled 315rwhp on 14psi need z32 afm and about 8psi more fuel pressure to run 20 -22psi...should see about 350 - 380rwhp after that.
Datsun 120y
RB20DET 20thou forgies stock cams & AFM
RB25DET Auto B&M Shifter
Garrett GT35R 0.64 exhaust housing 14psi
Unknown Walbro pump - Running out of flow
GTR Injectors
Remapped ECU by Mercury Motorsport
176kw
185kw was pulled but deemed too lean for safe driving. The fuel pump was unable to keep up toward the top revrange... Currently getting a Bosch 044 installed with a surge tank and relocating the AFM to before the throttle body.
Best 1/4 mile - 12.95 @ 113mph
Future mods..
Z32 AFM or aftermarket ECU
4000rpm stall converter
more boost
Wanting 250kw at the wheels
lastest figure out of my rb20
fmic
hks pod
sard r2d2 bov
sard fuel reg
r34 gt-r injectors
z32 afr
kkr 480 turbo
3 in dump to cat
3 3/4 in cat bak
power fc ecu
walbro intank pump
stock cams
stock cam gears
stock bottom end
stock plenum
stock ex manifold
power 264 kw @ the rears or 354.9 hp
92' R32 GTS-4
Rb20det
forged pistons
hks gt2530 turbo
apexi hybrid intercooler
hks pod filter
3" turbo back exhaust
apexi piggy backed computer to stock ecu
204.2rwkw
517.4nm of torque
Edited by RB26DETT_GODZILLA
post-32875-1162709094.jpgHey guys - My first post.. I have a 1991 240sx that I put a rb20det in.
I live in the US, but I've been browsing this site recently, as it has some very helpful info.
RB20DET-
Spearco FMIC
12 psi
Stock turbo
Stock internals
Stock clutch
Open downpipe
First run was with the stock fuel map, second run is corrected with an SAFC-1
On the same setup with 10 psi boost, I ran a 14.1 @ 98 mph.
That was a while ago though. Recently went back to the track with some boost controll issues, new LSD, and 9" slicks.
13.6 @ 103 mph (spun the tires. hitting .4 bar of boost, then slowly climbing to .7 bar) Adjusted the boost controller and hit a 13.6 @ 96 mph. I spiked to 1.1 bar in second gear, that quickly bled to .7 bar... I hooked 3rd gear and had no boost, but a huge splatter mark of oil where my BOV releases.... bummer! Oh well, good ET and poor trap speed. I've got video's if theres interest.
I am now workin on fitting a t04e/tial 38mm, 450cc injectors.
Goal is 400 hp/300 KW, before I tear into the block for some forged goodness.
R32 Skyline
Sliding Performance RB25 Hiflow for RB20
RB20 turbo wastegate
BOS importing split dump/front pipe
3" meatalcat
2.75" kakimoto JASMA approved catback
TRUST tube and fin FMIC
GTR 444cc injectors
GTR fuel pump
Remapped factory ECU
pneumatic/mechanical turbotech boost controller
NGK copper plugs gapped to 0.9
Stock cams, airbox, BOV, panel filter.
Run was done at 16PSI
Few things to sort out to reach full potential of 230rwkw
New plugs gapped to .8
New 3" catback
Z32 AFM
Lean the tune out
Then run 18PSI
hey guys,
I need some help.
Previous owner had my car dyno'd. He showed me the dyno sheet and it had 221kw on the sheet (since dyno's measure power at the wheels I assume this to be 221rwkw). The sheet also had my cars rego in the description so from everything on the sheet I saw it was legit but I've always doubted the power output (I didnt buy it based on the claimed power output).
Just for the mods it has, 221rwkw seems like a ridiculous amount of power from an RB20DET.
Basic run down is.
550hp Walbro fuel pump.
Adjustable FPR.
Vg30 BB turbo.
Hybrid FMIC.
3" turbo-back exhaust.
POD filter.
Exedy HD Clutch.
Bleed valve - 16psi (Thats what it made the power at, although I've only driven it at 14psi)
It runs stock ECU, AFRs tuned via FPR.
He also said it had bigger cams (I have no way of knowing) and he believed it might've had bigger injectors but I think they're just stock (They're red and so are the ones in my mates RB20 180sx).
So yeh, I'm pretty sure everyone here will agree it's not making that much power?
