R32 Rb20
GCG RB25 highflow @ 14psi
Bosch 044 in-tank
GTR 444cc Injectors
Std ecu remap
FMIC
3" Split dump+highflow cat+Fujitsubo catback
Std airbox
Turbotech boost tee
182rwkw 474ft/lb torque
Still room for alot more boost :/
Edited by r32woohoo
My resaults:
RB20DET S14a Z-Edition 297,1 RWKW
Engine management:
Haltech E6X
Haltech 6-pack of coils
Mangnacore 10mm sparkwires
Bosch 203 ingnition module
Head:
Ported intake\exhaust
Jun high rev valve lifters
Jun valve springs
Jun 292 degree cams
Adjustable camgear (but they still stand on 0 mark)
Stock headgasket
ARP headstuds
Newly recoverd the head, new guides, seats etc
Bottem end:
Stock pistons\rods
ARP mainstuds and ARP 2000 rod bolts
ACL racebearings
Grex oilpump
N1 water pump
Nismo 62degree thermostat
Engine exterior:
JUN style inntake
90mm throttle body
Re-enforced "CHINA EBAY" 6-1 manifold
Turbonetics 60-1 A\R .63 exhaust housing
3" exhaust from turbo and back
Tial 38mm WG
4" Fmic with 3" piping
555cc injectors running 3Kg fuelpressaure
2x MSD fuelpumpes with catch
  • 3 weeks later...
Lastest Result:
1989 RB20DET R32
3" Turboback Exhaust with 3" Metalcat
Hybrid FMIC
Bosch 040
GTR Injectors
Z32 afm
Turbotech Bleeder
Aerospeed cam gears
HKS 2535
DR DRIFT Remap
With latest tune...it made 217rwkw @ 19.5 psi...
Lower reading was from the last tune without the metalcat...
Edited by limpus
  • 1 month later...
1992, R32 GTST 62,000 kms on the clock.
the only thing i have modified on this car performance wise is:
HKS super sequencial BOV
Monza Pod filter.
everything else is stock standard and i got
174 RWHP
Edited by 18RZZ
Nissan Skyline 1989 R32
120000klms
190rwkw
254.4rwhp @ 13.5psi
standard injectors
R33 turbo
3inch straight through with split dump
GTR fuel pump
Fuel reg.
FMIC
Dr Drift computer
no BOV
K&N pod filter
Standard r32 bottom end
GCG rb20 hi flow turbo
orig hybrid GT spec cooler
GTR 440cc injectors
Apexi super induction pod
550hp wallbro fuel pump
wolf 3d v4 ecu
splitfire coilpacks
full 3inch exhaust
hi flow cat
CES dump pipe
18 psi - 210rwkw
Edited by Lukaz
1989 GTS-t 4 Door
stock rb20det
high flow standard turbo
fmic
3 inch turbo back exhaust
high flow cat
apexi air filter
stainless steel intake pipe
standard ecu
standard fuel pump
standard injectors
167.7 kw at the wheels @ 13.7psi with 640 Nm torque.
I need a bigger fuel pump and a reg as it tends to lean out.
soon im hoping to get a wolf 3d engine management and bigger injectors so i can up the boost and go for 200 kw.
92' GTST
Standard RB20
Standard RB25 Turbo
Unknown Front mount
Split dump pipe with high flow cat, 3" all the way
K&N Pod
Bosch 040
Turbotech bleeder
Haltech E6K
Made 177.0 rwkw at 13psi
Richens up to 10.5:1 afr after about 5-5500 rpm
had had mine tuned at xspeed in WA
stock engine
stock turbo
stock boost
mods
apexi pod
x-force 3" turbo back
just jap tube fine front mount
apexi neo
plain premium shell petrol
got 218 hp atw
i was happy with her :P
stock turbo, injectors and fuel pump
Apexi Pod
AutoBahn88 FMIC
Blitz SDBC Type S 0.9Bar
3" Downpipe
3 1/2" Decat
3 1/2" Apexi exhaust
SAFC 2
233hp ATH (173rwkw)
(plot is from MS Excel data logged on a Dynapack)
Edited by alexj
1992 r32 Rb20
144000k's
Stock Engine
Stock Turbo
Stock Inj.
SARD Adj. FPR
Walbro Fuel Pump
Greddy Profec b specII 1bar boost
Apexi Power FC
3'' Turbo back exhaust
600X300 Fmic
173rwkw
Edited by TeeJay1600
OK I finally got off my lazy ass and put the HKS kit on my car an these are the results.
Unopened RB20det
FMIC
Pod
GTR Injectors
Sard FPR
Bosch Fuel pump
HKS cast low mount manifold
HKS 2530 Turbo
HKS External Wastegate to screamer
Stock Airflow meter
Speed Lab tuned ECU
229.9 rwkw @ 17psi :thumbsup: finally some decent power!
RB20- Standard Internals
Hyper Gear HR43 High Flow Turbo
High Mount Manifold
External 38mm Wastegate, Screamer
Z32 AFM
550cc Injectors
Speed Lab Remap ECU
Running 19psi made 245 rwkw
^^ nice!
117,xxx known km RB20DET silvertop
RB25 s1 turbo w/ RB20 actuator
Xforce split dump, 3" front, "hiflo" cat, 2 3/4" back into canon
GTR radiator
FMIC
Greddy ProfecB spec2
Some generic mesh pod filter
standard untuned ecu
standard injectors
044 fuel pump
Made 183rwkw/246rwhp @ 12psi today on Hyperdrives dyno in Perth.. will post sheet when I've scanned it
To cut the list short -
Forged internals
Standard cams
Tomei cam gears (in anticipation for cams.....)
GT3540 turbo (high mount)
Turbosmart 38mm ext. wastegate (with screamer, love that sound!!)
110mm thick front mount
3 inch dump into 4 inch exhaust
Nismo 555cc injectors
Bosch 500hp fuel pump
Link ECU (upgrading to Microtech LT-12 this week)
Turbosmart E-Boost2
Alloy triple-flow radiator
Car made 293rwkw/393rwhp @ 21psi (more to come). Would post up the dyno sheet but I don't have a scanner!
Is also featured in current issue of ZOOM (# 118) :D
Dyno'd yesterday. A touch disappointed but here goes...
Internally Stock RB20DET (cefiro)
Fried RB25 Turbo
Stock Injectors
Malpassi FPR
Bosch 040 Fuel Pump
bleed valve (13psi)
3" hiflow Cat
600x300x100 FMIC
remote oil cooler
3A pod filter
152.5rwkw
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
