got mine bak
need an EBC cause my boost curve is shit atm u can feel the lag more cause its gota build up (no boost controller atm)
so get EBC might make bit more power but no to bad atm :P
206.9rwkw @ 14.5psi
A31 1988 Cefiro
Mods: Fresh STD rebuilt RB20 engine ~5000kms so far
Boostworx remapped STD ECU (still untuned for new turbo), Bosch 040, Hybrid front mount, very quiet exhaust (3inch), Garret T3G turbo ~15psi, Blitz pod and HKS EBC 2.
Now making 214RWKW at 15psi, dyno sheet to be updated soon
Edited by Ceffy_SA
1990 r32 gtst
gt3071r
550cc injectors
walbro fuel pump
tuneagent exhaust manifold
full exhaust system with custom dump
just jap cooler with custom piping
sm4 autronic ecu
stock internals
the car made 248.7rwkw but its now tuned at 241.4rwkw
ill try and post up dyno sheet but my scanner is playing up.
Thought I'd post up my old RB20 results for all to see :P
Car consisted of:
- internally standard RB20DET (silvertop)
- s1 RB25 turbo
- china fmic + piping
- Xforce split dump pipe
- 3" front pipe
- 3" decat pipe
- 2.75" cat back into canon
- 044 pump mounted intank
- generic metal pod filter
- Greddy Profec B spec2 (haven't spent much time smoothing out the boost curve)
This was untuned running 12psi (ignore the red line, that was when we tried to run 14psi, it made ~260rwhp but started to ping up high)
Edited by bubba
Mods:
Hks 2530
hybrid front mount
3 inch split dump> high flow cat (catco? i think) > trust power extreme 2
550cc siemens injectors
EMS Stinger 3
turbosmart boost tee
bosch 040
low run 12.5 psi
high run 17.5 psi
stoked goes well :P
  • 3 weeks later...
Internally stock rb20
turbo back exhaust straight through
apexi pod
hks evc
apexi safc2
stock turbo,injectors, afm
30 degree day.
237rwhp or 177rwkw
update soon with z32, hiflow33 turbo, bigger injectors.
img_Z050632_0001.pdf
RB20
garrett GT35-40R turbo
port and polished head
600hp fuel pump
750cc injectors
trust 600X300 front mount
apexi power fc engine management
3'' exhaust turbo back
k&n pod filter with cool air induction
Mathew Spry tuned it and it made 380 rwhp at 19psi and ran a 12.3 at 128mph.
RB20DET
standard Internals
177,000+Kms
272hp atw @1.2k boost
MODS:
Apexi Power FC
HKS 2535
External Wastegate 45mm? I should have measured it...
550 Denso injectors
Z32 AFM
Old style BLITZ? FMIC
Bosch pump
3in from turbo, hi flow(ed) cat
just got the car.
loosing boost at top end due to cheap bleed valve.
Im measuring 550km on one tank (40L) with highway driving. 350km for city driving...
Thanks to the guys at Hyperdrive!
Edited by ZOKU
1992 R32 GTS-t Manual
Stock turbo
FMIC
3" cat back
pod filter
20psi
BP ultimate 98
Every thing else STOCK ah yes slipping clutch
271HP 202Kw
Edited by Steve-o 45LDE
R31 Nissan Skyline
Engine: 1992 R32 RB20 Silvertop
Mods: 600x300x76 Intercooler
Custom 2.5in Stainless Cooler Piping
Stainless 3in Exhaust
3in Front/Dump Pipe
High Flow Just Jap 3in Cat
GFB Bleed Valve set to 14psi bleeding back to 11psi
HKS Pod Filter
Everything thing else is stock. Car was tuned by 'The Speed Lab'.
174.1kw
  • 3 weeks later...
RB20DET stock
HD Industries ex manifold , VL T3/T04 , Tial 38mm waste gate , bosch 044 fuel pump , bosch 363 injectors ,
Motec M800 , Custom plenum , 70mm throtle body , 600 x 300 x 105 FMIC
233 rwkw at 16lb boost
the 159kw was when it was powered by a L20B Turbo
STU
Edited by RB20DET BLUEBIRD
stock RB20
Hks 2530 @ 1.3bar (2510 rebuilt with garrett spec 2530 sized turbine)
GTR injectors
Blitz dualSBC
EMS
HKS dump into 3" zaust 2 mufflers no cat
600x300 fmic
lil disappointed but the motor is very tired
289.4rwhp @ 6100rpm
384.6 Nm torque @ 4600rpm
dyno sheet coming.
92' R32 GTS-t
Mods:
- Internally standard RB20
- GKTech split dump+front 3"
- 3.5" cat-back
- Apexi Pod
- Hybrid Front-Mount
- Bosch 040 Pump
- Running on standard boost = 159.0rwkw - Pretty happy with that.
Cheers,
Steve.
