got mine bak
need an EBC cause my boost curve is shit atm u can feel the lag more cause its gota build up (no boost controller atm)
so get EBC might make bit more power but no to bad atm :P
206.9rwkw @ 14.5psi
A31 1988 Cefiro
Mods: Fresh STD rebuilt RB20 engine ~5000kms so far
Boostworx remapped STD ECU (still untuned for new turbo), Bosch 040, Hybrid front mount, very quiet exhaust (3inch), Garret T3G turbo ~15psi, Blitz pod and HKS EBC 2.
Now making 214RWKW at 15psi, dyno sheet to be updated soon
Edited by Ceffy_SA
1990 r32 gtst
gt3071r
550cc injectors
walbro fuel pump
tuneagent exhaust manifold
full exhaust system with custom dump
just jap cooler with custom piping
sm4 autronic ecu
stock internals
the car made 248.7rwkw but its now tuned at 241.4rwkw
ill try and post up dyno sheet but my scanner is playing up.
Thought I'd post up my old RB20 results for all to see :P
Car consisted of:
- internally standard RB20DET (silvertop)
- s1 RB25 turbo
- china fmic + piping
- Xforce split dump pipe
- 3" front pipe
- 3" decat pipe
- 2.75" cat back into canon
- 044 pump mounted intank
- generic metal pod filter
- Greddy Profec B spec2 (haven't spent much time smoothing out the boost curve)
This was untuned running 12psi (ignore the red line, that was when we tried to run 14psi, it made ~260rwhp but started to ping up high)
Edited by bubba
Mods:
Hks 2530
hybrid front mount
3 inch split dump> high flow cat (catco? i think) > trust power extreme 2
550cc siemens injectors
EMS Stinger 3
turbosmart boost tee
bosch 040
low run 12.5 psi
high run 17.5 psi
stoked goes well :P
  • 3 weeks later...
Internally stock rb20
turbo back exhaust straight through
apexi pod
hks evc
apexi safc2
stock turbo,injectors, afm
30 degree day.
237rwhp or 177rwkw
update soon with z32, hiflow33 turbo, bigger injectors.
img_Z050632_0001.pdf
RB20
garrett GT35-40R turbo
port and polished head
600hp fuel pump
750cc injectors
trust 600X300 front mount
apexi power fc engine management
3'' exhaust turbo back
k&n pod filter with cool air induction
Mathew Spry tuned it and it made 380 rwhp at 19psi and ran a 12.3 at 128mph.
RB20DET
standard Internals
177,000+Kms
272hp atw @1.2k boost
MODS:
Apexi Power FC
HKS 2535
External Wastegate 45mm? I should have measured it...
550 Denso injectors
Z32 AFM
Old style BLITZ? FMIC
Bosch pump
3in from turbo, hi flow(ed) cat
just got the car.
loosing boost at top end due to cheap bleed valve.
Im measuring 550km on one tank (40L) with highway driving. 350km for city driving...
Thanks to the guys at Hyperdrive!
Edited by ZOKU
1992 R32 GTS-t Manual
Stock turbo
FMIC
3" cat back
pod filter
20psi
BP ultimate 98
Every thing else STOCK ah yes slipping clutch
271HP 202Kw
Edited by Steve-o 45LDE
R31 Nissan Skyline
Engine: 1992 R32 RB20 Silvertop
Mods: 600x300x76 Intercooler
Custom 2.5in Stainless Cooler Piping
Stainless 3in Exhaust
3in Front/Dump Pipe
High Flow Just Jap 3in Cat
GFB Bleed Valve set to 14psi bleeding back to 11psi
HKS Pod Filter
Everything thing else is stock. Car was tuned by 'The Speed Lab'.
174.1kw
  • 3 weeks later...
RB20DET stock
HD Industries ex manifold , VL T3/T04 , Tial 38mm waste gate , bosch 044 fuel pump , bosch 363 injectors ,
Motec M800 , Custom plenum , 70mm throtle body , 600 x 300 x 105 FMIC
233 rwkw at 16lb boost
the 159kw was when it was powered by a L20B Turbo
STU
Edited by RB20DET BLUEBIRD
stock RB20
Hks 2530 @ 1.3bar (2510 rebuilt with garrett spec 2530 sized turbine)
GTR injectors
Blitz dualSBC
EMS
HKS dump into 3" zaust 2 mufflers no cat
600x300 fmic
lil disappointed but the motor is very tired
289.4rwhp @ 6100rpm
384.6 Nm torque @ 4600rpm
dyno sheet coming.
92' R32 GTS-t
Mods:
- Internally standard RB20
- GKTech split dump+front 3"
- 3.5" cat-back
- Apexi Pod
- Hybrid Front-Mount
- Bosch 040 Pump
- Running on standard boost = 159.0rwkw - Pretty happy with that.
Cheers,
Steve.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
