309rwkw on 22psi
Rb20
Aries Pistons
Standard Rods
Standard Crank
Standard Manifold
GT3582r (.63 rear)
JUN cams and cam gears
Tial Wastegate
Microtech
Dyno sheet up later today
Fairly rushed tune that's fairly rich all round. At that stage we hadn't really finished tidying it up.
RB20DET - Stock motor
Custom Intake Manifold by Autoplus
Front Mount Intercooler with aluminum piping
3-inch full exhaust from downpipe
HKS Super Power Flow Filter
TurboXS Manual Boost Controller set to 12psi drops to 10psi
NISTune ECU
R32 RB20DET
HKS Cast Low Mount Ext Gate Manifold
Hypergear TR43 HF
Generic 38mm Tial Style Gate
Cam Gears
FMIC
POD
GTR Injectors
Z32 MAF
Remapped ECU
3" Turbo Back Exhaust
242 rwkw @ 21 psi (0% Correction)
Very Responsive for an RB20
R32 GTS4
rb20det
stock internals
td05h turbo
tial 38mm w/g, plumb back setup
rx7 flowed and tested injectors (550cc)
bosch fuel pump
Link ver5 ecu
600x300 hybrid style intercooler
k&n filter / custom stainless intake pipe
3'' full exhaust
turbo-smart ssq bov (type 2 vee port)
Running an Older Link is the problem here, cant keep up at the end and started to detonate, this was the highest run during tuning 221wkw @ 22psi.. Car is currently running 18psi @ 205wkw
Edited by Vanilla_Rice
  • 3 weeks later...
:D As requested
Post away you RB20 lovers
Hey just got back frm dyno yest an made 402rwhp/299.7kw@tyres at 20psi in my rb20 32
Mods consist
gt35r .63
cheap top mount manifold
700cc inj
sard fuel reg
3 1/2'' exhaust
walbro fuel pump
wolf 3d an controller
water/meth
intercooler
I have a rb20det motor with stock internals
front mount intercooler
k&n pod filter
z32afm
gtr fuel pump
gtr ingectors
kkr430 turbo
kkr dump pipe
3inch exhaust
nistune ecu
hks boost controler
i had mine tune on dyno at turbotechinics on 10/11/08 and it made 301.2hp atw it peaks at 18psi and drops to 16psi
Rb20 powered s13.5
- Un-Opened 9X,XXXkms RB20DET motor,
- Hypergear TR34 440hp ext gated.
- Tuned Length High Mount Manifold
- SARD INJECTORS....
- a fair bit more..... go to my link in signature for all mods..cbf em' typing all haha!
made 227rwkw on 17psi, with ext gate problem...and coilpacks shitting themselves...so should make more than that with new gate setup and my new packs ive got in on same psi..
but since then has been re-tuned to 14psi, while I get a new gate so I can run some more boost etc... and made 210rwkw on 14psi.. :(
will keep SAU updated on what happens...
***EDIT 3/02/09***
Today Micheal did another tune...
keep in mind it was a 37deg arvo here in Adelaide..
and my lil rb20 pumped out a pretty impressive 242.8rwkw on 21psi!!!!
effn stoked with that considering the day temp etc...
and backed it up with a few more 240+ runs as well just to show it wasn't a once off...
only thing ill be looking at doing is getting a bigger waste gate just to control a lil better as the KKR 38mm on its limits..
  • 3 weeks later...
RB20DET - Stock internals
R34 GT-T Neo turbo
ARC Front Mount
3" GKTECH Front pipe/Dump pipe
3.5" Trust Mild Steel Straight Through Exhaust with 5" Cannon
Decat
Turbotech MBC - Running 13psi
untuned
Made 171.1 atw on RE Customs Dyno
Should make 200atw with a tune!! :)
NISTune ECU
Just an update. We did a tune again today, after a major electrical overhaul.
Car is now pushing out 249.14 rwhp and 251.91 lbs-ft of torque. Boost set at 1.21bar dipping down to 0.8bar.
1993 R32 GTS-t
Standard RB20
ARC 105mm SideMount intercooler (50% larger than r34 gtt)
SplitFire Coilpacks
Apexi Catback
Batmbl Split Front/Dump 3inch stainless steel
Xforce hiflow cat
GTR Fuel pump
3A Raciing Airpod
HKS GT2530 with rb20 actuator
Standard Ecu - No Tune
Standard Injectors - maxing out
A lot of thanks to ReCustoms - www.recustoms.com.au
Update 26/2/09
GTR Injectors
Z32 AFM
TurboTech bleedvalve
Nistune - Tuned by Status Tuning http://www.statustuning.com
1.1mm spark plugs
A very safe tune of;
207.9kw atw @ 15psi with 11.5afr
Next update will be 18psi, adjustable cam gears and 12afr :)
Well i just picked up my new ride.. mods are
RB20Det Silver Top (RB POWAH) Lazer Cut In Coil Cover
Cooling Pro Intercooler
GCG Highflowed Std Turbo
Pod Filter
Engine Dampner
Walbro Fuel Pump
HKS SSQV BOV
Stainless Exhaust Manifold
Oil Filter Relocation Kit with Oil Cooler In Rhs Of Mspec Front Bar
Anyways It managed to make a lousy 183Rwkw On 14psi
I have Gtr 444cc Injectors and Z32 AFM all i need now is Power fc and a ballast resistor and then wind my boost up to 20psi and see how I go.. Happy dayz
RB20silvertop
big aftermarket front mount
bosch 040 fuel pump
GT30 highflow turbo
800cc SARD injectors
eboost2 controller
3" zorst
HKS pod
z32 airflow meter
aftermarket dump pipe
Made a lazy 230rkw on 15psi on a hot day !
RB20 silver top (145PSI comp across all 6, 0PSI difference)
TR43 (Garrett T04E internals), internal waste-gate, low mount
3" exhaust with mid and rear muffler
600x300x75mm front mount intercooler
Turbotech manual boost controller
Z32 air flow meter
Standard airbox (bottom half removed) with CAI
3" metal intake pipe
R34 GTR injectors
Bosch 019 fuel pump
Adjustable cam gears (inlet and exhaust)
NGK BCPR7ES spark plugs
Car made 208.8rwkw/364.1nm on 15PSI with a steady 11.5 AFR
Going back for re-tune with aftermarket coilpacks and expecting 220-230rwkw @ 17PSI
Big thanks to Trent at Status Tuning.
Edited by dmr
rb20det silvertop
gt2871r
std exhaust manifold
front facing plenum
haltech e11v2
gtr injectors
walbro pump
pwr 600x300 intercooler
PWR 42mm radiator
kn panel filter
splitfire coils
3" turbo back exhuast
224.1rwkw at 17psi :blink:
  • 2 months later...
RB20DET NICS
VG30 Highflow
R33 GTR Injectors
FMIC
Haltech Platinum ECU
3" Exhaust
Walbro 500hp Fuel pump
Greddy EBC
276rwhp on 18psi
300rwhp+ on 20psi (not exactly sure on figure, tuner backed off due to spiking)
Edited by HR31_RB20DET
    • This is the other log file, if only we had exhaust manifold pressure - would understand what's going on a bit better   Can you take a screenshot of your wastegate setup in the Kebabtech?   Engine Functions --> Boost Control (looks like this):
    • You just need a datalogger of some sort. A handheld oscilloscope could do it, because it will make the trace visible on screen, so you can look at the peak, or whatever you need to look at. And there are cheap USB voltage loggers available too. You could get a 2 channel one and press a button to feed voltage to the second channel at points that you want to check the sensor voltage, when you knew what the guage was saying, for example.
    • it's not the issue with making power, it's the issue with controlling boost, and this isn't the first time I've seen a 6Boost having issue with controlling boost down low.   The boost control here looks interesting.   Looking at your logs, looks like it's set to open loop boost control strategy (which is fine). We can see VCT being kept on till about 6600RPM (no issue with that). Ignition timing (I'm assuming this is E85, seems within reason too, nothing too low, causing hot EGTS and boost spiking). There's about 15 degrees of advance when your boost shoots up, however can't be this as the timing isn't single digits. I'm assuming there's no EMAP data, as I wasn't able to find it in the logs. We can see your tuner sets the WG DC to 0% after 4300RPM, trying to control boost.   My thoughts, what frequency is your wastegate set to?  AND why aren't you using both ports for better control?
    • While that sounds reasonable, this is definitely a boost control problem, but the real question is why are you having the boost control problem? Which is why I pondered the idea that there's a problem at ~4000rpm related to head flow. In that instance, you are not yet under boost control - it's still ramping up and the wastegate is yet to gain authority. So, I'm thinking that if the wastegate is not yet open enough to execute control, but the compressor has somehow managed ot make a lot of flow, and the intake side of the head doesn't flow as well as the exhaust side (more on that later), then presto, high MAP (read that as boost overshoot). I have a number of further thoughts. I use butterfly valves in industrial applications ALL THE TIME. They have a very non-linear flow curve. That is to say that there is a linear-ish region in the middle of their opening range, where a 1% change in opening will cause a reasonably similar change in flow rate, from one place to another. So, maybe between 30% open and 60% open, that 1% change in opening gives you a similar 2% change in flow. (That 2% is pulled out of my bum, and is 2% of the maximum flow capacity of the valve, not 2% of the flow that happens to be going through the valve at that moment). That means that at 30% open, a 1% change in opening will give you a larger relative flow increase (relative to the flow going through the valve right then) compared to the same increment in opening giving you the same increment in flow in outright flow units. But at 60% opening, that extra 2% of max flow is relatively less than 1/2 the increase at 30% opening. Does that make sense? It doesn't matter if it doesn't because it's not the main point anyway. Below and above the linear-ish range in the middle, the opening-flow curve becomes quite...curved. Here's a typical butterfy valve flow curve. Note that there is a very low slope at the bottom end, quite steep linear-ish slope in the middle, then it rolls off to a low slope at the top. This curve shows the "gain" that you get from a butterfly valve as a function of opening%. Note the massive spike in the curve at 30%. That's the point I was making above that could be hard to understand. So here's the point I'm trying to make. I don't know if a butterfly valve is actually a good candiate for a wastegate. A poppet valve of some sort has a very linear flow curve as a function of opening %. It can't be anyelse but linear. It moves linearly and the flow area increases linearly with opening %. I can't find a useful enough CV curve for a poppet valve that you could compare against the one I showed for the butterfly, but you can pretty much imagine that it will not have that lazy, slow increase in flow as it comes off the seat. It will start flowing straight away and increase flow very noticeably with every increase in opening%. So, in your application, you're coming up onto boost, the wastegate is closed. Boost ramps up quite quickly, because that's really what we want, and all of a sudden it is approaching target boost and the thing needs to open. So it starts opening, and ... bugger all flow. And it opens some more, and bugger all more flow. And all the while time is passing, boost is overshooting further, and then finally the WG opens to the point where the curve starts to slope upwards and it gains authority amd the overshoot is brought under control and goes away, but now the bloody thing is too open and it has to go back the other way and that's hy you get that bathtub curve in your boost plot. My position here is that the straight gate is perhaps not teh good idea it looks like. It might work fine in some cases, and it might struggle in others. Now, back to the head flow. I worry that the pissy little NA Neo inlet ports, coupled with the not-very-aggressive Neo turbo cam, mean that the inlet side is simply not matched to the slightly ported exhaust side coupled with somewhat longer duration cam. And that is not even beginning to address the possibility that the overlap/relative timing of those two mismatched cams might make that all the worse at around 4000rpm, and not be quite so bad at high rpm. I would be dropping in at least a 260 cam in the inlet, if not larger, see what happens. I'd also be thinking very hard about pulling the straight gate off, banging a normal gate on there and letting it vent to the wild, just as an experiment.
    • Not a problem at all Lithium, I appreciate your help regardless. I've pulled a small part of a log where the target pressure was 28psi and it spiked to 36.4psi. I've only just begun using Data Log Viewer so if I'm sending this in the wrong format let me know.
