*stock rb20 motor
*300zx 45v3 t3 turbo
*10 psi boost
*blitz bov
*blitz LM 3" intercooler
*2.5 intercooler piping
*3" free flow stainless exaust
*rebuilt gear box
*upgraded ecu chiped\remaped
*exeddy street and strip clutch kit
*iridium plugs
*oem oil seals and belts
*a/c compressor removed
*power steering pump removed
*walbro external fuel pump
*using castrol syntec
never ran on the dyno, would really like to know how much power we getting now,
will do a dyno run before we start mods to the motor tho
Edited by migs
first run
was @88000ks
on the 13/8/09
wit
arc airbox
gfb bleed valve
trust cooler kit
2 1/2 catback
mines ecu stage 1 ecu
stock turbo on 10psi
stock bov
and stock clutch
it made 142.5 kw atw (190hp)
second run
on the 04/11/09
R33 turbo on 12psi
drift vent to atmo bov
split dump
trust cooler kit
drift pod
mines ecu
tomie RRFPR
walbro fuel pump
gfb bleed valve
excedy cushion button clutch
and the same old shitty restictive exauhst
and misfiring coils
it made 162.1kw ATW(217.2hp)
the next tune to come on the 9/4/10 will be a good one i hope these are my current mods
splitfire coilpacks
remaped ecu by Cef11ie on here
hks evc iv electronic boost controller
drift pod
tomie RRFPR
walbro fuel pump
split dump 3 "ss front pipe high flow cat and 3 "catback with a hotdog before the diff and a cannon at the rear
R33 turbo on 14 psi HiBoost
8psiLowboost
drift bov
iridium plugs gaped to 0.8
and fuchs semi synthetic 15w-40 oil
am hoping for at least 190 to 200 kw atw (250 to 268 hp ATW)
will add pics when tuned with results
thanks for your time
90 R32 GTS4
110.000kms Rb20
3"zorst
Walbro 255lph intank
KnN pod
copper plugs gapped to .7
generic tube and fin FMIC
Link g4 ECU
R33 45V4 turbo - we bit tired
Everything else is standard on the car
Tuned by Shred industries performance @ 170rwkw
...picing up car today dont have dyno sheet on me yet will post up later tonght :cool:
Edited by Nightslug
1993 r32 gtst
std engine 130xxx kms
z32 afm
walbro 255l hr fuel pump
std turbo
big fmic
turbo back zorst
nistune
hdi ebc
hit 178.3 rwkw at 6000rpm on 12 psi while being tuned with 302 nm tourque
166.6 kw on 10.5 psi at 6000 rpm
  • 1 month later...
1990 r32 gts-4
stock internals
r33 s2 turbo
hks ebc running 0.9 bar
hks pod
trust pe ti catback and gutted cat
155.3kw atrw
putting a t70 on with 550cc injectorst soon ,will post both sheets up then
Engine. rb20det
Garret 2876r turbo .86 rear housing.
Turbosmart boost tee set to 14 psi.
Greedy frount mount intercooler.
4 inch intake with 3a racing pod filter.
Full 3 inch exhaust twin pipes. Now connon.
R32 Gtr 440cc injectors.
Z32 air flow metre.
Dr drift resistor pack,.
Dr drift re-map.
Bosch 040 fuel pump.
Drift oil catch can.
made 228rkw very happy with it, installing adjustable cam gears and another tune should get better response
92 R32 gtst
stock rb20det
r34 gt-t turbo
r32 gtr fuel pump
malpassi fpr
3" mandrel bent exhaust
gfb bov k&n pod filter
custom air intake
hybrid fmic
this dyno run was on 14 psi keen to do a run on 18 0r 20 psi soon ;)
1989 R32 GTS-t AUTOl 4 Door
Stock turbo
Boost 14psi (on the run, now at 12psi
Stock cooler
3in RS*R cat back
Drift small pod.
136RWKw
TEMP: 32
Humitity 95%
Edited by redliningr31 skyline
1993 r32 gtst 2 door
Stock internals
Stock turbo, stock airbox
3 inch turbo back zorst
Front mount, hks ssqv
Walbro 255l/ph, hdi ebc
Remapped computer
172kw@12psi
Ran 13.3@105mph street tyres
Really cold night at wsid
  • 5 weeks later...
HR31
Mods:
Turbo back 3 inch exhuast
VG30 turbo
Mines ecu
Walbro intank fuel pump
Boost tee running 12psi (spikes at 14psi)
147.5 rwkw
Was running over the top rich due to the ecu map, getting as low as 9:1.
Also still running the standard intercooler, so once my new cooler is installed and nistune installed I will hopefully get around 170rwkw.
I'm also thinking of cam gears so possibility of 180rwkw plus hopefully.
  • 3 weeks later...
1990 R32 GTS-t
RB20DET
3inch turbo back exhaust
Greddy intercooler
Random Pod filter
Greddy profec B boost controller
Stock fuel pump
Stock injectors
Stock computer
R33 turbo with r32 exhaust housing high flowed.
15.5 PSI 191KW
  • 3 weeks later...
Rb20det ECCS 'Redtop' 130,000kms
NIStune Type 1 Liveboard
Bosch 040 Fuel Pump
HKS 2510 Turbo
32 GTR intercooler
Malpassi Rising rate FPR
AU Falcon Coilpack Conversion
Blitz Pod
3" Kakimoto Exhaust
Standard AFM and Injectors
214.7kw, 370nM on Hubpack Dyno. Peak power at 5500rpm.
S13 rb20det
Hypergear tr43 .58 G1 profile top mounted ext gate
straight pipe no mufflers
gtr injectors
z32
nistune
Getting tuned next thursday will update how much power it makes
1989 R32
FMIC
Dump and full exhaust
APexi Power FC
Stock Air Box
Z32
500cc injectors
Walbro pump
GCG Rb25 Turbo
JJR coilpacks
16psi safe tune
198rwkw 540nm
Quite dead between 3-4000rpm then bang :) . Makes power 1000rpm later and 1000rpm higher than stock.
Will scan dyno sheet. Could go higher but looking for something reliable on the track for 30minutes.
Edited by spranga
S13 rb20det
gtr injectors
z32
nistune
Car made 207kw at 17psi with coilpacks breaking down, ended up re-gapping plugs to 0.8mm and am waiting a retune
