rb20de+t
kkk/ k26 turbo
stock injectors
stock afm
warlbro fuel pump
trust turnflow cooler kit
3in straight throw exhaust
made 196rwkw leaning out
gtr injevtors and z32afm this week and retune hopeng for about 210 --230 atw on 14ps1
  • 3 weeks later...
rb20DET
HKS 25/35 turbo rebuilt by RotaMaster
JJR 38mm external watsgate
Supertech forged pistons 20thou oversized
ARP rod bolts
ARP head studs
Cometic metal head gasket
Cometic gasket kit
nissan oil pump
nissan water pump
nissan idler pully
nissan tensioner pulley
NDC bearing kit
HKS camshafts, 264/8.5mm
HKS cam gears
Gates timing belt
Tridon thermostat
crank was grub screwed, balanced and ground
balanced pistons
balanced and resized rods
block was decked, bored and honed
resurfaced head
valve grind
new valve stem seals
exhaust guides and ports cleaned up a bit
braided lines
GReddy returnflo front mount intercooler kit
Gkteck dump and front pipe
Blitz cat back
Splitfire coilpacks
JJR alloy radiator
z32 AFM
GTR injectors and resistor pack
Status remaped ECU
Walbro fuel pump
JJR oil cooler relocation kit
gutted cat
238kw 19psi, 405nm
Edited by Kris..
  • 2 months later...
Full RB20DET rebuild with upgraded rods and bearings
FMIC
Full turbo back exhaust with performance cat
Greddy Dump Pipe
z32 AFM
Cold air intake
Splitfire coilpacks
550cc injectors
ECU Remap
Garrett GT2871R
Bosch 044
Exedy Super HD Clutch
230.3rwkw on 16 psi...
Dyno Sheet R32 GTS-T.pdfFetching info...
Dyno clearly shows 20psi
Edited by R31Nismoid
rb20det
greedy fmic
nisstune
full straight through 3" dump to cat 3.5 cat to back
.8 plugs
yellow jackets
rb25 hypergear hi flow
186 at 16-15 psi very laggy
Edited by Ke55pig
93 GTST 80,000ks
RB20DET unopened
Standard Turbo
GCG 15 psi Gate actuator
Dump pipe
full zorst
Ebay special fmic kit
Walbro Pump
Nistune - Envy Dyno
Pod filter
BP Ultimate
198 KW atw - Going lean at the top... Injecctors and Fuel pressure reg needed... O and standard turbo dying HARD...
Dyno sheet to come sorry..
87 HR31 GTS-R
rb23DET-R
Rb26 crank
Bored and honed 20thou for Arias oversized forged pistons –
7:9.1, comp ratio
Crank tested block,
Linished and crack tested crank,
Shot peened and Linished rods, Crack tested rods, blueprinted, Ported and Polished head,
New EXEDY 500hp 5 puck clutch,
Locked diff R32 gearbox with short shift kit.
This engine is built to with stand 450hp (335.7rwkw), 169 kW @ 8-psi 323NM
Garrett 30/35 3 inch stainless trust exhaust with trust drago muffler,
NO cat
ceramic coated manifold
WOLF 3D V4 computer
Malpassi fuel Regulator
Stage 3 turbosmart BOV
Oil catch can
Oil cooler
N1 GTR fuel pump
GTR 444cc injectors
Car is also a feature car in ZOOM magazine no: 28
1992 R32 GTS-T
Stock internals
R32 GTR FMIC
3inch catback exhaust
Apexi safc
K&N Pod filter
13 psi
Got a power run done down at RE customs in springvale. Made 170.5rwkw at 13psi using shell vpower. Been told since that RE's results are more than likely 10% out. Not 100% on this as I've heard nothing but good about them.
  • 1 month later...
Stock RB20 with 250+KM's on it only head gasket replaced
K & N filter
FMIC
VG30 turbo
Vr4 injectors
GTSlink tuned by Lithium
Walbro fuel pump
3" exhaust from turbo
running Mobil E10 98 on 14PSI of boost
this is before and after the tune with a bit more boost on the after.
  • Unopened RB20DET from a 1989 32 GTS-T (approx 100,000 kms if you believe the dash)
  • Drift brand pod filter
  • Just Jap Racing FMIC
  • Some random front pipe that a friend had sitting in his garage
  • 32 GTR Fuel Pump
  • Blitz factory remapped ECU
  • BP Ultimate
Car made 245.6 hp on EFI Performance's Dyno at 12 PSI during summer.
  • 1 month later...
1993 r32 gtst rb20det
Stock internals
New timing belt, seals, waterpump, thermostat...
Alloy radiator
Atr43g3 Hypergear turbo top mount
38mm turbosmart gate
Nistune ecu by chasers Motorworks
Cam gears
Turbo back exhaust with high flow cat
Return flow intercooler
Pod
Yellow jacket coil packs
Bosch 040 fuel pump
Denso 650cc injectors
Z32 afm
Bp 98 fuel
Made 225kws at the rears on 16psi
Very happy with chasers Motorworks tune
Edited by boz_soljah
1990 R32 gts-t rb20det
stock internals
splitfire coils, and plugs gapped to .8
deatschwerks 440cc high impedance injectors
walbro 500hp fuel pump
r33 S2 turbo (45v4)
Z32 AFM
triple core radiator with thermo fans
straight through 3.5 inch exhaust, hks super dragger canon
Maytech FMIC
Turbotech manual boost controller set to 15psi
Nistune
Tuned by Tom at PZP performance in clarkson, Perth WA
Made 271.9hp atw (203kw)
  • 3 weeks later...
Refresh Block
Crank Collar
Arp Rod Bolts
Arp Head Studs
HKS Gt2510
Apexi Filter
Mishimoto Rad
N62 Maf
Walboro fp
750cc injectors
Nistune
Fmic
3" straight back except elbow
Hallman Mbc set at 15psi
3.96 ring and pinion
2 piece drive shaft
..... and a slipping clutch
Edited by LeD ippen
Back with dyno sheet and re tune.
89 R32 gtst ( stock internals, stock injectors/ afm etc )
GTR size FMIC
VG30 Turbo
HKS Split dump into Kakimoto exhaust ( de - catted )
Supercheap Air Pod ( lol )
Bosch 040 Pump
Nistune
15 Psi
was hoping for above the 250 mark, but i am very impressed with how the car drives :)
  • 3 weeks later...
:action-smiley-069:
1990 R32 GTS-t
150,000 klm +
Factory sealed engine
RB25 high flow
Just Jap front mount and piping
GTR injectors
BP 98 fuel
Catch can
Power FC
Z32 AFM
Just Jap/China 80mm exhaust w/- bellmouth dump and decat
Bosch 901 external pump & swirl
China EBC
K&N filter in std box
PWR radiator
Some sorta clutch and diff
17" forged Weds wheels with 235/45 rubber.
Everything else bog stock rock, but goes alright.
Quite a "happy" dyno I reckon, but gives some idea.
:cheers:
Edited by Marlin
  • 1 month later...
hey..
1993 R32
RB20DET
HKs GT25/30 Turbo
HKS dump pipe, 3inch kakimoto
Walbro 255
FMIC
Standard ECU
Standard Injectors
Standard AFM
Profec B spec II
tuned by Unigroup for boost settings and timing
205RWKW at 16psi
injectors ran out of puff....
1989 r32 gts-t
Internaly stock rb20
Garrett 2835r
Denso 550cc injectors
FMIC
3inch stainless exaust
Z32 AFM
Bosch 040 fuel pump
Nistune Re map
232.7rwkw @ 16psi
