89 R32 GTS-4 Hey all, new here to SAU, just bought this GTS-4 and spent some cash the other day tuning etc
GT2871r
Trust FMIC
Turbosmart E-boost street
K&N pod
NIStune tuned by Boostworx
Turbo back JASMA zorst, (quiet)
Stock internals
Stock injectors
Stock FPR
14psi
Fairly cool day
Not that impressed really with this set up? I was thinking it would make a bit more thatn 188 with this turbo etc, need injectors and FPR= more boost. Did make like 580Nm tho which I thought was pretty sweet. Honestly im fairly new to RB's, mainly had Rotors before, PM what you think if your interested in having your say
Edited by 89 GTS-4
GT2871r
Trust FMIC
K&N pod
Stock internals
Stock injectors
Stock FPR
14psi
Fairly cool day
i recently bought my 32 gts4 after being into rotors for ages too.
mine made (oil pump failure = engine dead...) 144 awkw with std ecu, 15psi with rb25 highflow, 3", cold air intake, pod, avcr boost controller, and front mount etc etc. So 188 awkw is pretty good i think ! just make sure you have a good after market gauge for oil pressure and keep an eye on it....
1993 R32 GTST RB20DET
Stock internals
HKS 2530 Exhaust housing with Garret 2530 Compressor and middle
600cc Nismo injectors
Hybrid 600x300x75 Intercooler
GReddy Electronic Boost Controller Profec B
Z32 AFM
Full 3inch Exhaust from Turbo with Varex Cannon (No Cat)
AS Giken Adjustable Cam Gears
Have been told Step 1 Cams
Walbro Fuel Pump
Nistune
Adjustable GReddy BOV (Plumbed-back)
Apexi Pod Filter
Car made 184.4rwkw on 12 or 14psi at Horsepower In A Box. My aim is to have around 220rwkw when I get it retuned.
Unfortunately I'm selling the beast so thought I should put the power figures up.
1990 R32 GTSt RB20DET.
Stock internals - promise
R33 turbo with a r32 exhaust housing hi flowed
Greddy intercooler
Plazmaman intake manifold with custom intercooler piping to suit
GTR injectors with all wiring nessesry
Walbro intank fuel pump
5zigen 3 inch turbo back exuhst with custom made dump and cat
Drift air filter with custom made air box
Custom air intake pipe
OS gekken cam gears (was planning to get cams but never got around to it)
Spit fire coil packs
Profec B 2 greddy EBC
Apexi Power FC Pro (with launch control and all)
Lo boost 15 psi
Hi boost 19 psi
With the magic of power tune I am running 271 KW at the wheels.
Drives every day like a dream.
Edited by kila32
  • 1 month later...
Hey everyone might aswell post my results
Td06h-20g turbo 8cm housing
Turbosmart 35 external gate
Gtr cooler
Stock manifold with wastegate mod
3 inch exhaust
750cc injectors
Nistune
Stock motor
Car made 242kw with major wheel spin form 5 grand so prob closer to 260 I was told on 18 psi
Will post graph when I can now has a blown hg so building a 25/30
Ok my turn lol
Full forged engine,
Garrett GT2871
Nismo 550cc inj
spitfire coil pack
denzo 270lph pump
exeedy hd clutch
blitz fmic
blitz boost controller
APEXI FC
pod
full 3" exhaust from turbo inc hks dump pipe
Z32 AFM
few other minor things
right lol ummm 213rwkw on 22psi
currently in the process to correct setup from previous owner to hopefully get a decent dyno result. aiming for 280ish rwkw
  • 3 weeks later...
R32 GTST sedan
RB20 manual
RS*R 3.5" catback exhaust
3" high flow cat
3" split (plumbed back in) dump pipe CES racing
K&N filter
Blits SE FMIC return flow
RB25V2 turbo @ 14psi
walbro 500hp fuel pump
ADJ cam gears (dont know what settings)
Power is 160RWKW in darwin wet season.
R32 GTST sedan
RB20 manual
3" high flow cat
K&N filter
  • 3 weeks later...
Am curious to see results of any other 20s with td05 20gs-
ANYWAYS- unopened silvertop rb20-
R34 GTR Inj w/ resistor pack
Z32 afm
power fc w/ hand control
manual bleeder
fmic
full 3inch stainless zorst with 4.5inch tip and 2 inch screamer
turbosmart 38 ultragate
Bosch 044 pump
stock mani with flange welded on for gate
Mitsu TD05-20g
on a stinking hot 39 degree day with 20psi it put out 287hp with amazing pull from 4k to redline
Will upload dyno tonight...
Am happy with the torque as it hit over the 550nm range but not the end power figure as a mate had the same setup a few years ago and put out 329HP...
Looking at a kando td06 20g 8cm ext gate setup now as oil seals are going in mine and have been quoted 700$ to repair..
attached is the dyno (and my bad the figure was actually 285.5HP) -tho was told i could gain another 10hp by getting a bigger pod filter.
Edited by R31Nismoid
  • 3 weeks later...
Finished off my tune tonight, I had some brand new OEM Coils and 3 of them cracked causing a misfire, but sorted out with some Splitfires.
So my setup.
Stock RB20
RB20 Turbo Hypergear Highflow
3" Turbo Back Exhaust
Nistune tuned on V-Power 98 Fuel
GTR Intercooler
555cc Nismo Injectors
Walbro Fuel Pump
Splitfire Coil Packs
Greddy Profec b Spec II
Stock Airbox and KN Panel Filter
201rwkw @ 20psi (High), dropping a bit to 19psi and 174.6rwkw @ 14psi(Low). Did 206 with the cat removed, but the engine started pinging as the timing got advanced, so had to leave it with the 201 tune
Edited by cherring
Stock RB20
HyperGear ATR43SS1 (none PU version) turbo internally gated bolton to stock manifold.
Nistune tuned
Pump 98 Fuel
FMIC
480cc Injectors
Bosch 040 Fuel Pump
3inches hard intake pipe with Pod
227rwkw (green) @ 18psi
Gtr cooler
3 inch exhaust
750cc injectors
Nistune
Stock motor
After more inspection on the motor the inlet manifold gasket had a split on it the hg was still in good condition so that was the issue
  • 3 weeks later...
Rb20 Stock internals ,ecu,injectors. - R33 turbo - Fmic-3" straight through exhaust - Super spark coil packs. - Greddy profec b2 - Walbro pump - 165000ks.Bp ultimate
Made 195.2 kw on 16 psi - started detonating.Dyno'd @ 4b action Cardiff yesterday.
Edited by Lukez32
RB20det stock 100,000k
Ebay turbo http://www.ebay.com....=item230ecd1872
return flow cooler kit
3''bellmouth dump straight 3'' 5Zigen muffler
gtr injectors
z32
Nistune
spitfires coils
3'' metal intake
walbro pump
EBAY turbo maxxed out
205rwkw on17psi on a dynodynamics at 4B action Cardiff
211rwkw on 17psi on a Mainline at Boydys mechanical Centralcoast
Will upload dyno pic later
Unopened silver top rb20
Power FC with hc Z32afm Gtr injectors n resistor pk yellow jacket coils. Manual bleeder Fmic Cam gears. - tho set as stock currently Pod with custom intakeTd05 20g 7cmFull 3inch exhaust with 4inch muff Stock mani with mod for 38 ultra gate with screamer and 20psi of spring Bosch 044 Lightened flywheel -good sound on start up :-) Super single clutch Kaaz 2 way Lightened driveshaft
On 20.5 psi it put out 325 at the engine but had the timing severely put back as gate wouldn't open til 20 psi and starting pinging at 24 so had to tune from 20psi and not good. Full power by 4200 - 4400 and pulled very hard til 8k,also the torque was a fkn crazy 850nm banana.gif
Sorry for how post turned out, I done from iPad.
1330243832[/url]' post='6251695']
325 hp or kw?
Sorry man my bad it should of said hp. I will be getting 14 psi of spring into her to sort the timing issues out,a ebc and much bigger pod as my current one was choking ratios higher top end. Have dyno booked for two weeks so hopefully will post comparisons then. Edited by R31Nismoid
  • 3 weeks later...
GT2871r
Trust FMIC
K&N pod
Stock internals
Stock injectors
Stock FPR
14psi
Fairly cool day
yeah had the same sort of issue realy running 3 turbo back exhaust, link g4, fmic, 400cc injectors 25turbo @ 13 psi and was hoping for 190 to 200rwkw but only ever made 172rwkw. so 188 i would consider good IMO
Gday all,
I live in semi-rural QLD, Ive had my rb20 cefiro dynoed twice, about 2 weeks apart, no difference to tune. Its running a remapped standard ecu and I wanted to check the AFR's.
The two dynos were different by 72 HP at the same boost, what the heck?
Im very confused as to how they can be so different.
Also the first dyno operator said my AFRs were unsafe and it was a "bad tune" .
The second guy (lower reading dyno) however said AFR's were fine.
Who is right?
RB20det
Mods:
Garrett GT2871R .48 trim/0.64 AR
GTR injectors
split dump into 3 inch exhaust
FMIC
Z32 AFM
Remapped standard ecu for mods
(1st Shop- tried 2 eproms, 1st was a little lean 246hp on14psi)
2nd shop- 174hp run was 14-15psi, 2nd run 188hp 17psi)
2nd Shop- AFR plotted at 17 psi
One last question, I have a power fc sitting around- is there likely to be any gain to me if I put it on and get it tuned?
I'd really like 300 rwhp,
thanks Jes
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
