  • 3 weeks later...
Had my r32 dyno tuned today.
Hypergear atr43ss1 turbo with tial 38mm external wastegate
Hybrid side mount exhaust manifold
Cooling pro return flow intercooler
Jjr 3 inch turbo back exhaust with high flow cat
Bosch 550cc injectors
Bosch 040 fuel pump
Nistune
Pod filter
Made 297.6hp at 18psi of boost
A little lagier than I was hoping but it pulls well on full boost.
  • 3 weeks later...
89 gtst
jjr/kkr430
gtr injectors
gtr pump (i think)
z32 afm
China cooler
full 3 to 3.5in exhaust
Dr drift remap (from another car , was put in just for a temporary thing)
226.1rwk @20psi
Edited by toffy
  • 1 month later...
  • 3 weeks later...
1990 rb20det 180xxxkm
Stealth Return Flow Intercooler
High Flowed Steel Wheeled 34 Turbo
3inch Turbo Back
Split fire Coil Packs
K&N Pod
Standard Intake
Walbro Fuel Pump
Boost T set at 1bar of Boost
Standard Computer
259.7hpatw/193.6kwatw
1993 rb20det
150,000
fmic
power fc
z32
stock internals
800cc injectos
walbro fuel pump
3in dump to straight through
14 pound
apexi ax5370b
163kw :(
Edited by thomas.mcsherry
  • 1 month later...
  • 3 weeks later...
Ran my rb 2.2 for 4 years of solid drifting over 60 events in various stages from 98 ron to full e85 and a heap of different turbo and power setups, below is the last dyno and finally a main bearing went a couple of weeks ago so sold it off... but will put up results. prob forget a bitta stuff
Dyno was a hubber: 550hp and 600 nm at 23psi on full e85
Rb22
port and polished head
race springs
HKS 264 in / ex cams
Adj cam gears dialled in
rb25 crank rb26 rods
arias forged pistons 82mm
cosmetic metal head gasket
extra capacity sump
splitfire coils
vipec v88 ecu
1000cc ID injectors
full fullsetup, braided lines walbro lift pump 2 x bosche ext
aeromotive filter + fuel pressure reg
plasmaman plenum
greddy intercooler
greddy oil cooler setup
PWR rad
6boost
Gtx 3076 .82 rear
Tial 44 ext gate
rb25 box
both extreme and exedy clutches used
custom exhaust 3" to 3.5" twin pipes straight through
restrictors in head, massive head to sump drain, breathers from covers to catch can and drain back to sump
etc etc
Hey all, my r32 gtst type m '93
Standard engine internals
Stock Coilpacks
Stock injectors
Unknown turbo back exhaust 3inch/4inch tip
T04e turbo 18psi
Big FMIC
Gay pod filter (WTB stock air box)
Turbosmart wastegate w/ screamer... Ha :/
Manual boost tap
HKS BOV to atmo (making car stall like a bitch)
Tuned by ChipTorque
208kw... Yet to install Yellow Jacket coils and 550cc injectors and Turbosmart Kompact plumb back BOV
The RPM scale is a little off on the dyno also done to SAE correction on a Dyno Jet. The pulls were made to 8k rpm max boost was set to 18psi on 91 pump gas. The RB20 is in a S14. Wish I wasn't so scared to go over 8k :(.
Persicion SC61 turbo with stage 5 exhaust wheel
Griffen FMIC
Tomei 270 cams
Tomei valve springs
Tomei head gasket
ARP head studs
AEM S2 EMS
HK$ evc 4
Apexi GT spec exhuast
Sard 800cc injectors
Supra TT fuel pump
Rips intake manifold
Blitz dual surge BOV <~~~POS
  • Like 1
  • 4 weeks later...
'89 R32 GTS-t
Greddy FMIC
HKS filter
HKS low mount exhaust manifold
HKS wastegate
HKS 3" TBE
KKR430
Z32 AFM
444cc GTR injectors
BOSCH 040 fuel pump
237.6kw on 19.5
Lost the dyno sheets :( but it was done at PowerTune in Sydney
R32 gtst RB20DET
Deatchwerks 650cc injectors
Deatchwerks 320 lph fuel pump
Yellow jacket coils
Z 32 afm
bellmouth dump & 3 inch all the way
big fmic
Nistune
Rb 25 turbo @ 14 psi
180 killerwasps on a safe tune ( a little rich)
  • 1 month later...
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
