1992 R32GTSt with rb20det at 140,000kms
4sp automatic
170.4rwkw @ 13psi
mods:
- rb25 turbo (series 2 with nylon compressor)
- HKS cam gears: inlet and exhaust
- walbro fuel pump
- 3" split dump/front
- 3" high-flow cat
- 3" cat-back
- boost controller 14psi
- high-flow air filter in stock airbox
- rb26 cams
- some kind of chipped ecu, not sure exactly what has been changed - this was done before any of hte mods
- FMIC with custom piping
- auto tans cooler
- 2800rpm high-stall (MV automatics)
- stage 2 shift kit (MV automatics)
Dyno graph below
1991, r32 GTS-T
Walbro
POD
Turbotech boost controller @ 12psi
FMIC
On DR Drift's dyno got 135.8 kilowatts. Was really lame, most of the 31's at the place beat me and to make it worse, he said my car was running perfect
Need...New...Turbo...
New turbo on so
Walbro
POD
Turbotech boost controller @ 14psi
FMIC
R34 NEO turbo
Remap by DR drift
460N.M. Torque, 170rwkw was highest run, dropped down to 167 because @ 170rwkw it had some minor detonation.
Pretty happy, hitting full boost at 4200rpm, fangs hard through to peak at 5800rpm, comes onto spool at about 3krpm
Edited by r32 gts-turbo
1992 r32 gtst
198.7 RWKW
707.7 N.M Torque
15psi
mods:
- trust tdo5/o6 turbo
- turbosmart 45mm external gate, with screamer
- 3inch to 3 1/2 inch exhaust
- front mount
- 040 fuel pump
- malpassi reg
- safc 1
1989 Type-M coupe.
stock AFM
stock fuel pump
stock injectors
stock turbo running around 0.85 bar
3 inch Xforce turbo back exhaust
JJR intercooler 600x300x76mm
KN pod filter
home made cold air intake
142.7rwkw on Dr.Drifts dyno at night at about 15 deg i reckon.
happy with that for minor mods.
1990 R32 gts-t 43000kms
R32 gtr fuel pump
Z32 afm
rb25 turbo s1 (leaking from compressor seal, pretty shagged)
monsta performance FMIC
apexi power intake pod
3" turbo back exhaust
blitz DSBC spec-r
dr drift dyno tune
156rwkw @ 1bar
Edited by salad
HKS GTRS on RB20 in R32 GTS4.
215rwkw at 18psi.
Mods are the usual:
HKS GTRS
HKS Type-S intercooler
Z32 airflow meter
Nismo 555cc injectors
Full 3" exhaust
K&N pod
Dr Drift remapped stock ecu
Bosch 040 fuel pump
Dr Drift boost controller
BTW: BP ultimate is way better than Optimax! :whistling:
The dyno chart shows the difference in response compared to my old R34 GTT highflow. You can see at 110kmh I now have 50rwkw more than before, which is an amazing difference in drivability on the street >_<
type m 32 gts-t.
3inch trust turbo back, stock cat
walbro 450pump
300zx single turbo huffin 1.1bar
apexi air filter,
trust fmic
made 196.something rwkw, then we backed it off to a better torque curve and made 192. something rwkw, expected e.t at the drags ??????.i would post dyno printout, but i duno how lol
List of engine mods
Apexi air filter
Z32 afm
FMIC
3' dump to 3.5' cat-back
GCG Hi-flow turbo
GTR Injectors
Bosch 040 pump
Sard FPR
Spitfire coils
Turbo smart 38mm gate with screamer (14psi springs)
Turbo smart E-boost2
I asked Glenn at hyperdrive for 300rwhp and after along run pissin around with things here's the result... happy boi, its really not as laggy as the dyno run makes it out to be!
1989 R32 RB20det 4spd Auto
115000kms
mods.
K&N panel filter
stock rb25 turbo
r34 side mount cooler
3" combined dump & front pipe
3" hi-flow cat
3 1/2" Jasma from the cat back
$22 boost controller 12psi
SAFC-1 tuned by HITMAN
219RWHP
1990 R32 Gts-t
95,000 kms
stock turbo, injectors etc..
FMIC
Pod
3" Turbo back exhaust, hi flow cat, 3" viken muffler
turbotech boost controller
bosch 040 fuel pump
ecu remap by dr.drift
14psi
169.2rwkw
no dyno pic as yet
comming soon
1990 r32 gtst
stock turbo, internals etc.
stock ecu
dump pipe
3inch exhaust
stock cat
k&n pod
stock fuel pump
no tune done that i know of
13psi
165.5 rwkw
very happy with it soon im going to remap ecu and get a bigger fuel pump
Edited by burnsie
1992 R32 Gts-t
Stock Turbo, injectors, ECU etc etc
HKS Pod
3" Exhaust
Crappy intercooler (backyarder -> From japan :P )
Turbo tech Boost controller -> 9psi
And very recently installed Bosch 040 (Today :))
= 150.6 rwkw
171.3 RWKW @ 11psi
Standard RB20 Bottom End
RB25 Series 1 Turbo
Turbotech Boost Controller - 11psi
DrDrift Remapped ECU
R34 GTT Sidemount
3" Turbo Back Exhaust (very quiet/restrictive)
K&N Pod Filter with Heat Shield
Walbro 255 l/h Pump
D2 Fuel Pressure Regulator
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
