heya,guys!!
Have a problem for which sometimes, the rear speakers disactivate and after a random amount of time, it comes back to operation.
i took the rear seats off and got this diagram....
Question
I don't know where the green line connects to (labelled "sr1" or the crossover on sr1).
I found the connections from the AMP to the Crossovers are ok.
I only suspect the negative terminal of bridge 2(there are 2 bridges) being a bit loose.
here is a diagram. I took the backseats off during the weekend where it was 43 deg celc cause i can't stand this!!!
what else should I check?
i suspect it's now the
1. connections on my amp ,OR
2. connections on the head unit
HELP!!!
Could be a short that is causing your amp to go into protect mode. Once upon a time... I used to have a set of 6x9's that used to make a short screech then stop for a bit, then come back on and do it again... turned out to be a problem with the coils in the speakers that were causing it.
See if you can turn the stereo on, and jiggle the wires, as there should be some indicator of protect mode on your amp that you should be able to see.
heya,
did u try talking to your audio shop?
Edited by anexiole
hey crimpage,
yeah, i didn;t seem to find any indicator on the amp(Alpine V220) but yeah, very strangely, when i put my volume above 13, it seems to cause this problem when i go on bumps but when playing on volumes below 13,it is ok. Weird thing is that sometimes, playing on volume 13 and above is fine!! Darn..
i am out of ideas...
Mate of mine has the same problem in his holden barina or something.
He has 3-month old speakers and an amp. 6x9 sony's in the parcel shelf and a sony 2-channel amp.
There's no lights to indicate that it is going into protect mode (which I suggested to him), and the front speakers don't cut out (running off HU).
It only happens 80% of the time he's going downhill... We lifted the parcel-tray up (it's a hatchback) and it didn't happen.
Read this post and thought "what are the odds!?"
Randy!
that's is the exact setup i have!!
My fronts are running off HU . For me i think your protect mode thought is true because when i put a little more volume, it cuts out on and off in the rear which is runned by the amp.
Weird is that when the car is stationary it is fine but when i m driving on flat ground and i increase the volume, the cut outs happen!! Oh man!!
i hate this!
where did you learn of this "protect mode"? Did ur amp have it?
My amps have always had it, but my mates little Sony amp doesn't have any LED's at all! I'm pretty sure any modern amp has a protect mode, but it seems that they don't all indicate when it is in effect.
When his cutout happens, it can stay off for quite a while.
I told him that his power could be shorting on the body... he has a large power cable from the battery to the boot, with an inline fuse. I mentioned that the voice-coils could be shorting on the speakers, but when we lifted the parcel tray manually, nothing happened.
I was going to loan him my amp to see if the problem persisted, but I don't think he wanted to go through that much effort.
I'm still leaning towards a speaker malfunction, which forces the amp to shut down. (protect mode).
guys
for some weird reason , i dismantled the back seats again and moved the wires. So far, i can push the volume to 16 and no issues(touch wood)...
i was suspecting the "Gain" on the amp like one of you guys suggested but it's now workin'.
"If it ain't broken,don't fix it!"....
thank you ,everyone!!
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
