hey guys thinking of putting a 25 box in the ceff
ok i know i will need a 25 box + tailshaft, is there anything else i need?
i know i will also need to modify the tailshaft to fit and i have heard a couple of ideas about 'bearbox' crossmember???? can be slightly modified to suit (whatever this is) and SLAVE CYLINDER????? also not bothered about speedo
HELP
https://www.sau.com.au/forums/topic/103164-rb25-box-in-ceff/
  • Replies 103
Okay once again from the very VERY limited knowledge i have it is all a pretty easy swap but i think the 'yoke' needs to be shortened??????!!!
Good source of knowledge for conversions to Cefiro's is this site
d1nz.org.nz/forum
Since the Kiwi's get the cheaper RB20e auto versions 90% of the time they all are conveting them! :D
My useless 2c ahaha
Ando
no worries
also from my calls today - the 33 yoke is needed and keep the ceffy tailshaft - just needs to be modified
also all the gear selector etc is interchangable from what i've been told
can also use rb20 gearbox crossmember
possibly need the transtunnel 'massaged' a little wider...
Ok I've had it done.
Transtunnel is fine. Dont need to touch it.
Obviously clutch, fly wheel etc all the same.
You will need an R33 clutch slave, I got mine new from nissan for $88.00.
Yes you need the R33 yoke, then you need the cef tailshaft, the idea would be to shorten this. However if your center bearing is stuffed like mine, then you might want to look at getting a 1 peice shaft as this is cheaper than replacing the center bearing apparently (lighter also, so you get back some of that extra weight of the gearbox + less rotating mass)
Rb20 cross member is fine, we just moved mine and put some spacers in. You might need an engineer to look at this to make sure its legal. Mine is actually mod plated.
The speedo... You need your red gear off the R33 speedo sender (the one that goes in the gearbox) this then needs to be attached to a navara speedo drive (32702 - 02G17 pinnion assembly), should be about $22-25 new from nissan, this then connects up to your speedo cable like normal. Just test it tho, should be pretty accurate.
Get some of the seals replaced on the box if they need it. You REALLY dont want oil leaking on to your clutch.
Get your fly wheel/pressure plate/clutch all checked out while the box is out. I had to replace mine that was a cost I didnt allow for.
And why does the gear selector matter? Wouldnt your RB25 box come with one? I dont belive we used my RB20 one.
But yeah, once its done your more afraid your crank is going to snap in your poor little rb20 than your gearbox :)
thats exactly info i needed thanks heaps DD :domokun:
gearbox i'm getting has got yoke etc - clutch was just fitted recently also .
now the hunt is on for a r33 clutch slave
and if its that cheap to get speedo working i'll do that aswell :) - just gotta make sure that red thingo is there
whats it look like? and where?
thanks again - awesome info
Yeah dude, just go down to nissan and get the slave $88 cant go wrong.
OOOH!!!
BIG BIG BIG ONE!!!
You MUST get an S1 gearbox. If you get an S2 your going to have a LOT of stuffing about. The clutches are different (ie one pull ther other push)
AWSOME Article DD... this needs to be stickyed in the parts list of these forums...
shame u didnt type it out when i needed it 4mths ago ;)
Hehe, dude thats prob when mine was getting done :rofl:
hey, im doing the opposit of you guys in a way. im putting a r32 rb20det in to my rb20e powerd r33. i have the electric speedo. what i have been told is that i need the r32 gtst drive gear. what does it look like and where does it go?
cheers
LUCKILY i got an early model box with push type clutch ;)
When fitting the R33 gearbox, what modifications are you guys doing to the propshaft? We are putting an RB25DET engine and box into my cef and where wondering what the deal is?
Is there a propshaft that fits? Or do you need to make one.
Regards
Chris
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
