Thanks folks,
Sorry about the whole "Tailshaft/Propshaft" thing. Trying to translate aussy english into Uk english can sometimes be challanging!
Shorten the tail/prop-shaft... Check....
Im guessing it's worth while getting it ballanced...
Chris
  • Replies 103
Thanks folks,
Chris
I would hope any decent shop would include that in the price...
ok asked for a r33 early model clutch slave cylinder today - was told there are 9 different ones - so more specific - i said suit rb25turbo roughly '93 model RWD... still came up with 2 choices - but the one he did offer me was $88! new
DD - you got a part number or anything or did u find there were 2 different ones - coz this guy wanted me to find vin#/chassis# to help define which one - but i told him its for a box conversion
thanks
update
box is bolted up - no modifying to the transtunnel and kept the standard crossmember but turned around (with spacers added)
getting the yokes swapped over on the tailshaft - pickup later in the week
ordered the r33 clutch slave cylinder - pickup tomorrow
HOPEFULLY it will be as easy as this!!! ;) should be finished by the end of the week :huh:
  • 3 weeks later...
awesome write up. :)
does anyone have the part number for the rb25 box slave cyl?
also, when changing from rb20 auto to rb20 with rb25 5 speed. what master cylinder can i use? only r32/ceffy/laurel? or wil a s13 one do the trick? or are they all the same?
cheers
matty
Edited by mattysaidso
shit i should've checked it when i bought it... :)
nissan dont give out part numbers for whatever reasons... but i ordered a series 1 / r33 / skyline slave cylinder - 93 model (early)
and i was given the correct one - i was told on here they're about $88 but the quote i got from nissan was like $110 - so i quoted the price and they actually did it for $88!!!
  • 3 months later...
great information, so basically i need a series 1 box with yoke and things should be fine
someone has also informed me a nissan terrano or z32 yoke will work
im also a bit interested about the piece needed to make the speedo drive work, does anyone have a pic of this?
Edited by SirRacer
Its piss easy dude. Someone has pics I think.
But the actual cog bit, that goes inside the gearbox, the rb25 one should be red. You pull that off the rb25 electronic speedo gearing thing. Then you pull the one off the navara one, and somehow get the rb25 one on. Just the gear, not the metal spline thing.
Did you read the first page?
You need.
S1 RB25box and yoke
S1 Rb25 box clutch slave
Navara speedo drive (code is somewhere on here) -(pics are also somewhere on sau, might take 30mins of searching tho)
Custom/shortened tailshaft
Move the cross member
Modification plate
I seriously cant think of anything else we needed. While its out tho I would clean up or get a new clutch, and machine the fly and pressure plates back. Just saves on money. I would also put a cheap oil in the box for a month or so, cleans it out, and you dont throw away good money on good oil if the box is stuffed.
Good luck!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
