Hi guys.
With the new section, its looking a bit bare, best thing to brighten it up are good useful sticky threads :)
If someone has an idea, post here or PM me.
I was thinking if someone can post up formula's to workout diff ratios and things like that... would be very handy for a sticky.
You'll be credited with the information of course and all that :D
Throw ideas out there
-ash
  • Like 1
https://www.sau.com.au/forums/topic/103170-this-section-needs-help/
  • 4 months later...
um. To figure out any gear ratio the formula is: the number of teeth on the driven gear (crown wheel) divided by the number of teeth on the driving gear (pinion) eg: crown wheel 20 teeth, pinion 10....
SO 20 divided by 10 = a ratio of 2:1... easy.
Evan
  • 1 month later...
  • 1 year later...
  • 2 months later...
i whould just check the diff have never come across a single diff that did not have the ratio stamped onto it some where with out a plate on it some where
so why try and work it out?
Edited by neofenrir34
Because people get diff gears changed
can we get a thread up on recomended oils to use in gearboxs, vlsd and mechanical lsds. say in my gearbox i use fuchs 75/90 because i found the redline shockproof crap and in my kaaz 2 way i use fuchs ls140 with ford motorsport additive. i notice alot of people use castrol syntrax and find it good
  • 1 year later...
  • 1 year later...
Is it possible to get a sticky thread made up about 33 boxes into 32's. So many people still cant use the search function. I know there are a few good threads about the conversion maybe they can be put into one thread?
  • 5 weeks later...
I think a sticky on gearbox identification would be awesome, like being able to tell by the webbing on the housing/dimensions/weight/any numbers stamped on box, gear diagrams, 1piece/3piece syncros stuff like that :)
  • Like 1
  • 4 months later...
heres a link from nismo that has all diff types ,ratios & models they come out in
http://www.nismo.co.jp/products/competitio...f/lsd_price.pdf
there is a lot of usefullinfo on the above but cant seem to find out wether my 32 has a VLSD or just a LSD (?)
  • PranK unpinned this topic
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
