my headlights when on low beam, use the only outside globes(and the far outside ones), and high beams use only the inside...my question is, is this different to others? are the different models...different? as in, do the high beams use the outside ones aswell?
next question...can you understand this?
:D:P
https://www.sau.com.au/forums/topic/10318-just-a-quickie/
There's a kit from www.PerfectRun.com.au that allows you to turn on both hi and low beam when the light stalk is on hi beam position, this is to get more ilumination. Brand is East Bear. Kit is pretty pricey I reckon, about $180 plus not including delivery.
If someone know abt electronic, I reckon it will probably just some wiring harness, isn't it?
https://www.sau.com.au/forums/topic/10318-just-a-quickie/#findComment-163815
Originally posted by pushead
highbeam globe and the normalbeam globe are separate. They both got their own compartments.
i realize this...but try tell that to a dickhead behind a counter with his head up his ass...the thing is, when i asked him if it what he was saying was true, he asked another guy there...same answer
https://www.sau.com.au/forums/topic/10318-just-a-quickie/#findComment-164989
You can get brighter globes, I run 130w on my GTR high beams and it makes a massive difference as I think the standard lights are crap with the 85w globes. I do a lot of driving at night and do not like to not be able to see everything. I have been used to really bright lights on other cars and the gtr's just dont cut it for the performance of the car.
In terms of keeping the low beams on when the high beams come on you simply need to run a diod (Sp) in the wiring between the high and low bean trigger wire so that power can run too the low beams when the highs come on. You may also need to run a relay to help boost the high beam switch depending on what condition it is in. This will cost about $2.50 for the diodes and getting somone who has a clue to put them in for you. If I can next week I will give you the wiring colors.
Mick.
https://www.sau.com.au/forums/topic/10318-just-a-quickie/#findComment-165731
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
