Hey mate,
I've just recent;y put some of these in my 180 and couldn't be happier. Easily compliant enough for the road, and for mild track use should also be tip top, but I'll let you know after the 11th!
I'm running the jap spec ones, not the aussie modified examples
Thanks for the feed back. I was looking at the jap spec ones, the guy at the suspension shop told me these run a 5kilo spring.
5kg/mm is 280 lbs per inch, that >70% higher than the standard spring rate.
Most Australian lowering springs (Whiteline, Kings etc) are 20 to 30% higher rate than standard.
:( cheers :(
I am currently running the Australian spec teins in both of my cars, r32 & evo9, and i am very happy with the results, in the evo the ride is softer than when i bought the car, but can be firmed up( i am using the in cab controller, saves trying to get in behind the bootliner to adjust, with this setup the car came second in the last round of the mt cotton hill climb championship(standard everything except an exhaust and airfilter), i think they are great value for money.
in the gtr which i also ran at the hillclimb , the car was good enough for first place (46.1). the set up for street is perfect with no harshness or lack of spring control, the car is very comfortable to drive daily! also as a note the coilovers i took out were jap teins these things were like riding on solid blocks!! , i may firm up the gtr setup as the car is being pushed fairly hard but fulcrum will be doing that for me with a slight spring rate increase and revalve.
(this car is a track day car and ran 10.87 last time at W.S.I.D)
for more info on the teins, a gentlemen by the name of graham at fulcrum in brisbane was instrumental in the valving and spring setup for the Australian spec teins with tein engineer from japan.
i hope this information is useful, but remember it is just what i found when using it on my cars.
cheers Russell
(the suspension was good enough for 56.8 on the sprint track at Q.R on semi slicks & 1:01.61 on the clubman)
  • 1 month later...
Sorry for digging up an old thread but I just want to know, to purchase the "Aussie Spec" ones, is there anyone in NSW to go through to get them ?
Also, what's the going $'s for a set ??
Cheers.
    • Interesting. My tuner said after the tune that my fuel economy would be better but it is the exact same from what I could tell even though my car was running rich before lol. How much do km do you reckon you get on a full tank of petrol on your commute?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
