Hey just wondeirng if i'll need to trim the fan blade off of my r33 gts25t series 1, if i install my new hybrid gt-spec intercooler kit,.Ive heard people say that with the new gtspec kits, theres no need to trim fanblades?as id like to do it myself, im not too keen if i will have to trim fanblades, as i'll probably ruin sumthing, its the one thing thats stopping me from diy'in the fmic.
One other thing.....my piping doesnt have a nipple for my solenoid going back to turbo???is there another line i can tap into?, or should i be getting a nipple put in?
thanks
Did this not long ago.
I trimmed the blades before fitting it up, and in retrospect probably didn't need to. The pipe going across just behind the radiator sits up pretty high - i would try to fit without trimming, i reckon you'd come darn close.
Otherwise, if you need to cut them - i just did it with wire cutters. it's only the back of the blades that needs attention, anyhow, and just a little snip at 45 degrees should do it.
with the "nipple" - just plumb into either the vacuum line out of the front of the manifold (to the fuel reg) or the one that goes to the BOV.
Oh and btw you won't need to cut the front fan plastic shroud, either (for the aircon fan).
Whole job took about 5-6 hours, and i'm no whiz with the tools :(
some people chop out some of the bumper reo bar to get the cooler to sit back some more .and yes its not uncommon to have to trin about 5 mm off the fan blades to clear the piping . u may also have to relocate your hoen as well in cases
^ Ah yes, forgot to add that a trusty angle grinder was required for the reo bar :(
And you'll need a hole saw too. There's plenty of exciting new homes for your horns when you're putting everything back together.
For what it's worth, when i picked up my cooler i was told that Autobarn installs them for about $100 or $150, (i can't remember exactly how much but it seemed pretty reasonable). But i'm one of those ppl that prefers to do everything himself.
Edited by Beeble
Thanks so much guys, im going to do this tommorow hopefully if i get the time, how much off the fanblades will i need to cut off, and could u please post a pic of where i cut from/to?
If i cut the blades wrong could i do damage to the cooling system in effect?
please help guys, i got the cooler fitted, only top brackets are on, sits nicely, and i will have to relocate the horn, but thats the least of my worries, the piping that needs to go back to the stand piping hole is too short, or so i think, do i need to make the hole bigger or something???ive moved the cooler right back so i cant understand why this is happening.Also with all these hose clamps, how much do of the pipe needs to be over the clamp before i tighten, sorry new to this diy stuff (heheh)
Although you may not have much choice, trimming fan blades is a bad idea coz it might make the fan out of balance and consequently may affect other things like water pump, engine cooling, etc You could extend the piping by having a longer silicon hose from where the washer bottle is, and for the pipe that goes across the engine lift it with a small metal bar and 2 extra bolts.
Ok i'll try that hopefully all is fine. Just wondering........... if i was to lift the pipe going accross the engine, would that not make the pipe hit the bonnet???, and would that affect the rest of the piping that extends to the cooler itself?
cheers
It's quite tricky and yes the top pipe might touch the bonnet as well. Like I said you will need a longer silicon hose (probably twice as long to the one off the kits) and a metal bar roughly 5 cm2 to lift the top pipe clear the fan. That metal bar will be bolted on the where the engine mount is with 2 extra bolts for the top pipe. I havent got a pic for you but hopefully you can understand the mess that I just typed :)
This is a common problem if you get the Hybrid kits. Apparently the manufacturer is too lazy/cost saving to make some other kits that do not touch the fan. If you want a Hybrid cooler, might as well pay a little bit more and get some custom made kits to avoid this problem. But I guess its too late now :D
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
