A high flow cat has been proven to increase horsepower by increasing the amount of gases that can pass through it, but what makes it flow so well? Is it the number of cells (small squares you see when looking through the cat) per square inch/cm? Why does a metal-inside cat flow better than a ceramic-inside?
https://www.sau.com.au/forums/topic/103203-high-flow-cat/
I was under the impression that a metal honeycomb can be thinner, with larger cells because the metal heats up much more/quicker than ceramic material does, therefore burning off unburnt fuel etc much more effectively than its ceramic counterpart.
The pics i've seen of the Magic Performance cats reveal a "straight-through" design much like straight-through mufflers... It's just a steel tube through the centre of it with lots of holes.
https://www.sau.com.au/forums/topic/103203-high-flow-cat/#findComment-1898015
Have no cat at all that would make more horse power just gotta watch for emission testin. When i brought my 32 i had no cat on it and had to put a magic performance cat on. Ive seen a car that would start up and the second you put your foot on the accelerator it died. Took ages to relize it was the loose honeycomb part in the cat blocking the exhaust flow
https://www.sau.com.au/forums/topic/103203-high-flow-cat/#findComment-1906089
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
