Go the genuine nissan.
The nissan one brings engine temps up quicker and holds them more stable. The aftermarket items fly open to wide and to quick causing temp fluctuations.
If the car runs under 80degree's (which my experience is the aftermarkets do cause it to do so) then the ecu refers to its cold enrichment table. As a result you use slightly more fuel.
Compare the two side by side and the genuine most definitely looks much more meatier and reliable.
Do a basic test to see if its working. Put it in some boiling water and see if it opens correctly. Or better still put some water in a jug with a thermometer and gradually add hot water to it til it reaches 80 degrees to see if it is opening at the correct temperature.
around $39 last time i got one.
just ask for R31 skyline item. (they are the same at 76.5deg open)
otherwise they will charge more as soon as you mention import.
thats all genuine Nissan im talking, don't waste time with aftermarket jobs, they can be more expensive and perform poorly.
Edited by RB30-POWER
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
