Hi all
Does anyone know the part number for a coolant temp sensor so that I can ring nissan and order one.
If your wondering why i'm replacing it (others could have same problem) its hard to start in the mornings and is running really rich.
Thanks all any help muchly appreciated
(I would have done it on nissan FAST myself but I got a new computer and didnt save FAST.)
https://www.sau.com.au/forums/topic/103256-r33-gts-t-s1-coolant-temp-sender/
When I ring Nissan, they look that stuff up for me. Trying to find it in FAST isn't easy.. the electrical and cooling system are in different sections, and the electrical one is huge and confusing by just looking at diagrams.
Where are you located?
Did you check the sensor resistance at various engine temps ??
Anyway the PN you are after is:
22630-44B20
But double check when you order and tell them it's in Section 210 for the R33 model.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
