My Jim Berry clutch is for sale. EASILY holding 265kW and still going strong. What no-one's mentioned is how cheap it is to have Jim rebuild them back to BRAND NEW SPEC.
$450 tops!
I want $550 ono for mine. Wont last long.
33 gtst.
Adrian
Wierd thought i posted this before but here it is again.
Direct Clutches in Albion Brisbane are one of australias premier places for clutches. Some of you might not remember the judge and his high hp cars, well he used direct exclusively.
And i dare say his cars where making more power and torque than 99% of users on here.
You will not be dissapointed :P
$450 tops!
33 gtst.
Adrian
ill take it alright.
  • 4 weeks later...
im quite interested in the amount of pressure (power) some of these clutches can hold up to.
im looking at putting out around 350kws atw and have been told ill need a tilton twin plate with custom flywheel. is this necessary??
You should call Jim. But he said mine should hold about 800hp at the fly fairly easy, its his superdooper single plate one. If you do all the conversions you still have head room. But just call Jim better to get it from the horses mouth.
Jim usually rates HP on circuit applications so if you put slicks on the rears, rev it to 7000rpm & then dump it on a well-prepped track like Willowbank like I did, well....tore my carbonic down to the rivets. Ended up going to a NPC twin plate and it is bulletproof + only $200 to rebuild as opposed to $700 for a single plate.
Mine is ready to pick up from Jim now and i distinctly remember him asking me what i will be using it for even went down to percentages. EG:80% street, 15% circuit, 5% drag. So if you specify what you want to do with it he will give you what is necessary to do the job.
Deren
Edited by Godzilla32
A mate with a 240awkw gtr got a heavy duty clutch (told it was good for 300awkw) off NPC and his first outing at the drags saw pretty aweful clutch slip.
I got jim's full monty, and upon asking him what it'll hold in my 26/30, he said it should see 1000+hp
Got a single plate Exedy sports tuff ceramic from western clutches was told itll hold 500-550 hp
Not happy at all done about 2000km and on the first launch it flared to 8000rpm all of 1st and 2nd gears had to back it off 2 times to make it grab in 2nd. In gears in dosnt flare.
I dont recomend to anyone this Shit clutch.Unless you feel like wasting $900 + the labour fees.
Edited by nismo 400 R N1
i live in NZ and shipping something the weight of a clutch probably wouldnt be worthwhile so i was just interested theoretically as various "experts" have such differing opinions.
I would ring Jim however the chance of me buying something off him is small and i dont want to waste his time.
There are second hand clutches galore around at the moment. If i was to buy a nismo twin plate how much approximately is the rebuild costs on something like that.
Cheers
Edited by SirRacer
Im thinking of gettin a clutch of jim.. however could someone please tell me how much labour would cost for installing this clutch?? cauz im in vic so i need to get it installed somewere else...
I've been quoted $250 labour to install a clutch into a GTR. Previously paid $300 for a GTSt (about 5 yrs ago). Cost of machining flywheel would be extra.
Both workshops in Melbourne.
  • 4 weeks later...
Ive had a Jim Berry "race clutch" in my 33 for the last 18 months and it has never slipped and was running 300rwkw. I know have closer to 400kw and even a 6500 launch and slicks still didnt slip. They are awesome.
My R34 GTT needs a new clutch... was going to go for a twin plate, but maybe Jim is the better option? I'm in NSW so can he build it all for me, then send it here and I get it installed by someone else? It's for an R34 GTT and I want it to be able to hold about 265rwkw, does anyone have a rough idea on how much it'd cost?
Im in Tassie and i got mine delivered with a standard flywheel for less than $1300 but that was a while ago. I did have a Nismo twin plate and that was hard to press in when this clutch from jim is nice and easy but grabs hard.
how much was that?. i am awaiting a call from him tomorrow. mine made just over 700hp at engine and am wondering whether a single will do
cheers
Put me down as another happy customer of Jims, also got the full monty from him, have had it in the car 6 months now and haven't had any problems at all...
and as stated before alow at least an hour out of your day for the phonecall.. Jim loves a good chat
My Jim Berry clutch was so good it was as easy to drive in my 320kw gtr as my budget exedy was in my 185kw r33 gtst.
Just don't forget when ur getting a new clutch to spend the extra $500 and get a new flywheel with it :happy:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
